Weld grinding
Discussion in 'The Hokey Ass Message Board' started by 81ttopcoupe, Dec 1, 2008.
  1. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    I have started patching up my frame, got the first patch(12gauge) in place, ground the weld smooth on the outside with my 4.5" grinder, but it won't reach the welds on the inside so I need to use my die grinder. I havn't used it much though I have a range of stones/wheels(?) and burs for it. What is the preferred grinding tip for a die grinder for grinding weld down? I have grey, pink, and white stones and various metal burs, various shapes if all.
    Thanks.
  2. VonMoldy
    VonMoldy
    from UTARRGH!
    I would try to use 36 grit fiber disc if you can they work great. If the space is really tight you can cut down a bigger disc as long as it is the stick on kind.
  3. I'm with VonMoldy, I think you'd be better off using a sander. But if you're stuck using a die grinder:
    The bit you are using should look "fine," not "course." The course bits are for metals like aluminum and ***anium. Try to use one with a pretty big footprint so your work comes out smooth. Grinding a weld is kind-of like a sanding block, you want to use the biggest abrasive surface you can so your work levels itself out. But make sure you are only dressing the weld, not the metal around it. Especially on a frame you need to be sure you are not making the area around your weld too thin.
    As far as the "fine" vs. "course", try your bits on a peice of aluminum. One of them will gum up, that's the one you want for steel. The difference in appearance between the two is drastic so if your not sure which one you've got, it's probably for steel.
    I hope this is helpful and not too wordy.
  4.
  5. chopolds
    chopolds
    from howell, nj
    You might even look into using those 2 and 3 in. flap discs they make for die grinders, they work great! I'd use a carbide burr first, if the weld bead is high (like a MIG weld), then finish with a 2 or 3" disc.
  6. jambottle
    jambottle
    i was of the opinion that grinding down welds is for cosmetic reasons only;unless you are making another p*** for better pentration.welds inside of a frame rail are best left alone.(if they can not easily be seen).
  7. rustyford40
    rustyford40
    from Mass Bay
    When you grind the welds you weaken them.
  8. Nobodys Hero
    Nobodys Hero
    from New Jersey
    i use green 36 grit 3M discs...there great wouldnt use anything else
  9. Offy
    Offy
    #36 grit disc with a rubber backing pad, sometimes #80 grit for smoother finish.
  10. AlbuqF-1
    AlbuqF-1
    from NM
    If it's a full penetration weld, properly made, it doesn't (unless you somehow overheated the metal by grinding). On something like a frame you don't want the frame to "look" different in cross-section at a weld than the adjoining metal, like a stiff spot in the middle of flexible material.
  11. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    Thanks everyone for your tips. I don't think I have anything I can get a 36 grit disk on that will get inside the frame rail, though I will do have a the sanding disk for the 4.5" grinder so I can use that on the outside of the frame rail. Is there a tool for a die grinder that will would work? What sort of sander would y'all recommend? I'll have to make a trip to ACE or Lowes and see what they might have.
    The welds are MIG, I'm still learning to weld so penitration is not always the greatest, hence the welds inside the frame also, besides using weld in smaller rust affected areas to build up the material back to it's original thickness.
    My thoughts run in line with what AlbuqF-1 said about the cross-section, a high spot would be stiffer, putting more stress on the metal surrounding the weld, thereby promoting the possibility of cracks around the welds. For a really stiff frame that might be OK, but this is by no means a stiff frame.
  12. Dreddybear
    Dreddybear
    I use the edge of a cutoff wheel and feather it down to the point where it's just above the surrounding metal. If you want man I'm willing to come over tomorrow after work and check it out with ya.
  13. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    Hey Dreddybear anytime. I tried the cutoff wheel, I like that better than the die-grinder and stone I had in it. Maybe a combo between the cutoff and the die grinder. I would like to find some way to try some 36 grit in the die grinder, I think that would be better.
    I need to get my welding books back out, otherwise I am going to spend a fortune on abrasives.
  14. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    As i get better at welding I am grinding less. Got a flap wheel for the 4.5" and that thing is awesome! I had a craftsman surface prep attachment for the die grinder but it didn't last very long. I will order new one with a bunch of 3M disks after Christmas.
    Sanding is better than grinding, but better welding is even better.
    Next question, what do you guys use to keep from breathing in welding fumes/dirt?
  15. PASTDUEBILL
    PASTDUEBILL
    Nothing you *****.
    Just blow black snot in the shower like the rest of us.
    I like rat tail files. You can detail welds pretty well with a new, sharp rat tail file.
  16. jj mack
    jj mack
    Thats funny.
  17. Dreddybear
    Dreddybear
    Oh my god that is funny.
    Funny cause its true. I blow black snot all the time.
  18. srdart67
    srdart67
    from Sharon, Wi
    ahahahaha i do that everyday of my life. just breath them in they wont kill ya:D for a little bit at least. and if your that worried get yourself a scba.
  19. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    Awe, :eek:, geez, I think I've been shot.
    Not looking to make them to pretty, just hide my ugly welds.
  20. srosa707
    srosa707
    from Sacramento
    If your putting a gusset over a weld, do you guys grind it down for the gusset to lay flat or do you jsut put it over the weld?
  21. ehdubya
    ehdubya
    These 1/4 turn 2" discs rule on an angle die grinder.
  22. sko_ford
    sko_ford
    when they are black and red then ya got to worry ;)
  23. Dr.Kerry
    Dr.Kerry
    I use carbide tips at work. Just an idea I guess...
  24. BanjoBoy
    BanjoBoy
    I would also liket to know so bttt
