suicide doors
Discussion in 'The Hokey Ass Message Board' started by 021k26rr, Dec 19, 2008.
  1. 021k26rr
    021k26rr
    from TN
    Anyone ever install suicide doors on a 54 chevy.Do you have to brace up the b-pillars alot.Anyone recommend a kit that they have used.
    thanks
    Ben
  2. fordcragar
    fordcragar
    from Yakima WA.
    What body style are you working on? You shouldn't have any problems with a sedan, because the "B" pillar should be strong enough; a HT might be another story.
  3. hrm2k
    hrm2k
    You have to watch how the hinge is constructed. Your door has a roll that has to be considered. We did a 51 which is much more potatoe shaped than yours. We didn't see any kits that were for big old 50 s door. It took a bunch but our doors do not droop and they swing freely. There may be some pics on my profile in the 51 Shavrolet album
    Good luck
  4. Fenders
    Fenders
  5. fordcragar
    fordcragar
    from Yakima WA.
    I'm not crazy about them either, they look like more problems than they are worth. The money spent on making them work well, could be spent in better places.
  6. hot rod rich
    hot rod rich
    from NorCal
    Ive used the suicide doors hinges on my little bros 97 chevy fullsize and they worked out great! That door weighs a ton and those hinges def do what they were built for!
  7. 021k26rr
    021k26rr
    from TN
    Thanks for the help guys.Anyone got any under construction pics.
    Ben
  8. 29nash
    29nash
    from colorado
    I like suicide doors, converted those on my daily driver '29 chevy pickup. Of course not a comparable model for you application. I'll offer this.
    The structure of the door itself might use some strengthening in the web and where the hinges will be attached. I would reinforce the pillar also, just to be safe. Doublers, rectangular patches of 16 gauge steel should be adequate. If you plan to chop the top, I would convert the doors first, then incorporate that with the chop. My suicide doors give me more leg room getting in and out of the car than I had before.
  9. lanny haas
    lanny haas
    from Phoenix AZ
    I used the stock hinge on my 68. added a channel in behind the jamb to mount them to.
    Added a 1 1/2 black pipe to the gas tank nounts and welded the pipe to the channels to support them. I made mounts on the door the same depth as in the stock location and they swing inside the body and not outside like the kit hinges that you can buy.
  10. hrm2k
    hrm2k
    Here is a shot of the door jam on the 51. I know I have some real detailed photos somewhere. My buddy and I have both said that if we had it to do all over again, we would use a uni-hinge ( single hinge in the middle of the door ). The hardest part of doing this was having the hinge not only open the door but also swing the door away so it cleared the body when opening. Ours is still very close to the body. We had to add stops to keep the door from opening too far and hitting the body just behind the doors
  11. might try WEscott in Oregon they came up witha kool hinge kit that might work for ya
  12. 021k26rr
    021k26rr
    from TN
    Do they have a website (wescott).Thanks for the pic on the 51.Is the hinge on that car like the hinge that suicide doors sells.I have been searching the net and it looks like most everyones hinges are the same.Who makes a uni hinge? do you think it would sag over time.
    Thanks
    Ben
