Halibrand Experts Out There
Discussion in 'The Hokey Ass Message Board' started by FunnyCar65, Dec 25, 2008.
  1. FunnyCar65
    FunnyCar65
    from Colorado
    I have a Champ rear with all the wide 5 junk on it,can it be changed to conventional axles and lug bolt pattern?Who sells parts for them?
  2. alteredimage
    alteredimage
    I needed to extend my QC, got new tubes, big ford ends , and axles for a 9".
  3. Pewsplace
    Pewsplace
    You don't state what type of champ you have but any style can be changed to Ford 9 inch axles and housing ends. If you have the Ford tubes try Hot Rod Works in Utah. (Google for info). If you have round tubing 2 or 3 inch you can have them converted by any machine shop with a alignment bar. Speedway Engineering in LA does a very nice job. You can use brakes from Currie or a junkyard to replace the wide 5. Axles are available from several sources or you can use pre 72 Ford F150 axles with 31 splines and and a 5 1/2 inch bolt circle. Dutchman in Portland can solve all of your problems.
  4. donut29
    donut29
    from canton MI
    I want to do the same thing to my Frankland QC it to has the wide 5's but I want to run 9in axles and backing plates. So that I can run my 16x5 ford wheels
    dose anybody know if I can run a Detroit locker from a 9in in my Frankland QC-80. I dont want to buy a locker if it wont work
  5. FunnyCar65
    FunnyCar65
    from Colorado
    I'm new to quick changes I had this one given to me,what's the differances in the champ style Halibrand?
  6. 29pu
    29pu
    i believe one has 11 studs and the other has 12.
  7. Ken Smith
    Ken Smith
    Alliance Vendor
    FunnyCar65 and donut29,
    We've been working on new posi differentials for the Champ rear end. We can also set up the housings to take conventional brakes. Give us a call after the Holidays or email us.
  8. brokenspoke
    brokenspoke
    My champ rear has 12 spline spool...does anyone know if a Ford F1 has 12 spline axles?
  9. Babyearl
    Babyearl
    Speedy Bill,, Speedway Motors-Lincoln, Neb
