Who has a '49 - '52 Chevy car with a Camaro clip?
Discussion in 'The Hokey Ass Message Board' started by J Man, Dec 30, 2008.
  1. J Man
    J Man
    from Angola, IN
    I have a '50 Chevy running a second gen ('70?) Camaro clip. I have 15x4 wheels and some sort of racing tire in the front. The tire seems to rub some.
    I am looking to get different wheels and tires on all 4 corners. My question is what size wheel and tires are other running on this style car with a Camaro clip. If you know the backspacing that would be nice as well. If you have a picture post it up if you get the chance. Thanks
  2. norby48
    norby48
    from NW Indiana
    I found that clip to be too wide for my '51. I went with a 74 Nova clip. It is narrower. You need wheels with different backspacing. I also set mine up centered in the wheelwells, not forward as the stock centerline was. It looks better and gave a little more turning clearance. Sorry the pics don't show more. I haven't loaded the other pics in the 'puter yet. I was able to use stock 15x6 rally wheels. As I said, you need to determine what backspacing will work for you.
  3. old dirt tracker
    old dirt tracker
    from phoenix
    if it was mine i would build a new frame with a must11.but in your case i notice the really late models the kind that have about 20 round holes in the wheel have a ton of offset.
  4. BadLuck
    BadLuck
    I was in the same boat a year ago. Had a camaro clip on mine. Wrestled with it for about a year. Trying different wheels, offsets, trying to line up original sheet metal, radiator support...looked into narrowed control arms ($1,000)....the frame horns end up right behind the grill, couldnt even get a finger in between the fenderwell and tire....nightmare!! Yeah, there are people running them and are happy with them, but for the money I thought I was going to save and the months and months of frustration, wasnt worth it. I bought another frame from a HAMBer and hacked off the camaro clip, grafted on the original front end (because my rear was already notched and bagged) bought a Mustang II, was installed in a few hours, all my sheet metal bumpers,etc bolted right up. These clips are just too wide. Just my experience, hope this helps, good luck....
  5. sk_rodz
    sk_rodz
    I had a 50 chevy with a firebird clip. when I got it, it had steel wheels and bigtime clearance issues. I didn't want to make any radical changes, so I ran late 90's S-10 factory mags and 50 series tires. no problems with clearance and my bumper sat about 3-4 inches from the pavement.
  6. sk_rodz
    sk_rodz
    I don't know what kind of a "look" you are going for, but here is what mine looked like.[​IMG]
  7. zman
    zman
    from Garner, NC
    I'd rather rebuild the whole car than run those ugly wheels. Or order the same offset in steelies. :eek::eek:
  8. chopolds
    chopolds
    from howell, nj
    I've got on in my 46-8 Chevy coupe. I ordered a set of custom steelies form Wheel Vintiques to help the issue. They are 15 x 5 or 6, with 1 1/2 in. backspacing ( EDIT...NOOOOOOOO...I meant front spacing! moves most of the tire toward the inside). Or maybe 1 3/4....it's been a long time since I got them. They fit "OK" but will still rub if the car sits very low, but I've got airbags on it to raise it a couple inches. Narrowed A frames will help, as well as running metric rotors every little bit helps, and they all add up to being driveable, in a no-so-perfect situation.
    You still won't be able to run it VERY low without something to lift it while driving. But in a normal traditional 50's type stance, you should be OK.
  9. J Man
    J Man
    from Angola, IN
    The rubbing I am getting is not bad but it still does it. I do not like the wheels and the front tires are junk so I need to switch them anyways. I was wanting to try and not do the narrowed arms due to the cost. A previous owner pulled out the inner fenders so that is not an issue.
  10. Custom54
    Custom54
    I don't have a 49 - 52, but a 54 with a 79 Camaro clip. It was too wide for the ride height I was running. I use stock rims with 1" narrowed control arms and it works for me.
