Let see all the custom made frames...
Discussion in 'The Hokey Ass Message Board' started by SinastirSpeedShop, Oct 4, 2007.
  1. I like to see everyones frame they have made. Include the size and gauge of metal you used.... THANKS
  2. fatabone
    fatabone
    Here is a ch***is Clark and I built out of 2x4 and 2x5 with the x-member and front cross member made out of 3/16. We built a jig to curve the rails to fit the body.
  3. CheaterCarl
    CheaterCarl
    I love frames & ch***is, they make me feel warm. sometimes I think it's a shame to cover them w/a body.
    Carl of The Cheaters
  4. CheaterCarl
    CheaterCarl
    Here are some s***y ch***is shots of CheaterKory's model t roadster frame.
    We used 2 x 4 Square Tube w/Model A front Frame horns & a Model A rear cross member. We copied a Dagel X-member & made our own. It turned out nice. The car goes down the road like, nice & straight.
    Your Friend,
    CheaterCarl
  5. JimSibley
    JimSibley
    heres the ch***is to my 32 Im building. Its 2x6 .166 wall with 1.75 d.o.m rear kicks, and a model A cross member.
  6. tmacracin
    tmacracin
    Nice work! It looks wild!
  7. Keep them coming...Nice start. I am my planning stages of mine and I want to get so ideas of what others have done. Thanks
  8. atomickustom
    atomickustom
    Dumb question: How are you guys curving that 2x4 square tubing? I can figure out how to put a bend in it (notch, bend, weld), but how the heck to you get a flowing curve?
  9. nailheadroadster
    nailheadroadster
    "Holy" bad*** frame Batman!!!
    Aww c'mon... if I didn't do it someone else woulda.
    Looks killer man!!!
  10. lakesmod
    lakesmod
    11ga X 2" X 4".
  11. Shifty Shifterton
    Shifty Shifterton
    This is my frame, but can't claim construction credit. 2x4 side rails with 1x2 mid members and repro model A crossmembers. The side rails bends are the result of a lot of saw and TIG time, and tapered up front to around 2x2. She's sturdy but a little street roddy for some tastes. Should make for a real solid and predictable car though.
  12. 60 Belair
    60 Belair
    here a few of my 27 t sedan frame .
    had to throw in the 32 with 409 cause its bad *** ,
    its a friends​
  13. CheaterCarl
    CheaterCarl
    I can't get enough of this frame thing!
    IT's details baby!
    Be proud fellas, they all look killer!
    Cheater Carl
  14. blue 49
    blue 49
    from Iowa
    I don't have any good pictures, but I made mine out of used 2x5 pallet rack crossmembers. About .080 -.090 wall thickness. Not on the road yet so it hasn't been proven, but seems very sturdy.
  15. woodbox
    woodbox
    Here is some shots of my tube frame for a 1927 T.
    I have used 1 1/4" Boiler tubing with 1/8" wall thickness. Front end is tortion bars onto a 46 front axle. Rear is 46 truck to get a quick change centre on final ***embly. All body panels hand fabbed in steel, except cowl and sides.
  16. Alf
    Alf
    Here is my home made frame. It's built from 1.5 by 3 by 1/8 inch box tubing. It still isn't quite finished, I plan on adding a couple of cross members that include drive shaft loops. The suspension is transverse leaf in the front and parallel in the back.
  17. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    This is mine for my 28 rpu lakes car, 32 side rails from Speedway that I flattened and pinched, 18 inches at the front, rear cross member is fabed from 14 ga the front is 1-3/4 dia x1/8 wall 4130.
    Rex
  18. matthew_caine
    matthew_caine
    from texas
    awesome frameage guys!
  19. matthew_caine
    matthew_caine
    from texas
    oh yea that 32 coupe with the huge blower is totally bad***!
  20. need more pictures of this one. dig the engineering.
  21. Crankhole
    Crankhole
    Awesome!
  22. daveheld
    daveheld
    35 Ford frame... original side rails with .120 wall round tubing backbone. I didn't make the frame, just the IRS.
    dave
    http://www.321irs.com
    Cocoa Beach FL
  23. daveheld
    daveheld
  24. Jimmy Nitro
    Jimmy Nitro
    It's my 41 International still in the making.
  25. Toast
    Toast
    from Jenks, OK
    Never took any pics of mine with the cab off?? Not as nice as the others but here it is.
  26. Jimmy Nitro
    Jimmy Nitro
    More of the same
  27. Jimmy Nitro
    Jimmy Nitro
    More, more of the same
  28. NITROFC
    NITROFC
    From the Shark Attak ...
  29. hotrod-Linkin
    hotrod-Linkin
    this frame was made with sticks
  30. This is one of the coolest threads! I love metal fabrication.
