i found a 1948 ford. i was wanting to know if anyone knows how wide it is? i have a channeled 32 that i was thinking of using it on. i want to run 16''s and i want it to be close to the body? thanks
Bishop and Tardel's book states that 35'-41' axle was 32.85 inches per side - about 3/4" longer than the 32' - and 33.70 inches per side from 42'-48'. It's on pg. 49 if you have the book. I agree try to keep it tight as possible. If I did the math right a 48' axle ***embly is about 3" longer than the 32'.
The 46-48 rear ends are the widest "banjo" rear ends Ford made. By about an inch on both sides. On a channeled car those extra inches can be the difference between wheel rub and wheel clearance at the top of the wheel well. I'm using 48 bells on my model T project. And the clearance is tight.
