55 Cadillac Floorboard thickness
Discussion in 'The Hokey Ass Message Board' started by crackernutz, Jan 10, 2009.
  1. crackernutz
    crackernutz
    from tx
    Guys, any idea what the thickness might be on my floorboards. I'm going to be patching some holes tommorow and I need to know what size thickness sheet metal to buy also need to know to set amperage on welder . thanks :confused:
  2. crackernutz
    crackernutz
    from tx
    would 18 gauge be about right? think a stick welder is too much for that thin of sheetmetal?
  3. flynbrian48
    flynbrian48
  4. DHD
    DHD
    from Ottawa, ON
    Stick is not going to work so well, also if the floor is getting punky you might want take a close look at the mounts as well, I had to rebuild all of mine during what was going to be a simple floor patch job. There are 11 mounts per side from the firewall to the rear wheel tub:eek: Fortunately some Jack*** had previously "fixed" them with thin gauge aluminum and caulking, and covered it all up with heavy undercoating!
