Hot Rods Finally a new UPDATE of my Canadian Sedan Build
Discussion in 'The Hokey Ass Message Board' started by Kruzer63, Jan 11, 2009.
  1. Kruzer63
    Kruzer63
    Hey kats, so i keep getting people emailing me askin wheres a new update... well when you are always workin on it its hard to get a good update created... anywho i took some time this morning to put some pics together for you guys... enjoy the new updates... you will see that i have been busy... or well...may prove that i truly have lost my mind...
    So earlier this past year i managed to get the moon style tank mounted up front, and did so in a way that allows it to appear to be floating with no mounts..
    I then had the brackets welded to the tank and now it appears to float in its space.
    I welded some tapered rails to the underside of the 2 x 3 tubes so that it gives a true model A frame look from the firewall forward. But in adding that i discovered that i had to put a bit of a notch for my tierod to clear better... so i made a swoopy notch.
    Heres where i started to lose what was left of my mind as i spent a week of evenings grinding with the carbide tip in the die grinder, and smoothed out all the welds front to back... and molded it all before sending it to the painter...
    Late one night we loaded up the ch***is and sent it for primer and finishing. Thanks to Paul for the use of his old full size ford, as my lil S10 wont quite carry a ch***is.
  2. Kruzer63
    Kruzer63
    While the ch***is was gone and the car is all blown apart it was time to start building the mill for it. So i spent more time then i planned on it but hey somethings i had never done before... such as porting and polishing the head... what a pain in the *** to do...looks good now but its not enjoyable in my opinion...
    then the head was fitted with custom one off length swirl polished stainless valves... thanks to Primatech for getting me those along with the radical cam to match. OHC Pontiac six parts are not common when it comes to aftermarket so you have to spend some cash when you are psycho like me.
    This is the Belt drive, which houses the oil pump, fuel pump, distributor, oil filter, and oil pressure regulator... what a grimy mess... it is however aluminum...
    After sanding to 1200 grit and polishing...
  3. Kruzer63
    Kruzer63
    Now is where i went crazy polishing things...namely any piece on the engine that bolts on and is aluminum... its all polished now...
    Here is the belt drive cover, early models were aluminum so i tracked down one of these and Tombstone worked his magic helpin me polish it up. Tombstone also polished the Cam tower for me too which i will show off once i get it on the engine. I have also spent too much time polishing about 4 dozen stainless ****on head allen bolts for this engine as well as grinding the heads smooth and polishing hex bolts too...
    Here we have a before shot of my oil pan... this was the good one out of the pair i had... so it was time for some metal work... and like a crazy person i decided to bodywork, and get the pan sprayed in a deep gloss black as well have it cut and polished too...
    Here is the Pan in its finished form, just finished pinstriping it yesterday...
  4. Kruzer63
    Kruzer63
    Now due to the engine mounts originally being under the oil pan and now they are out along side it, it causes some flex and stress on the bolts holding them in place... my old 53 poncho has had bolts break many a time so i figure with the ponys this engine will produce i better build a brace to firm up the engine mounts and make sure nothing flexes. Instead of doin a tube like some people have, Tombstone suggested maybe i could build a I Beam styled one... and i took that to another level, making it mimic my front axle...
    Then of course i molded it completely smooth like everything else, as why stop now right...
    Here it is in its finished look, just picked up recently from my painter... black on the outside with PPG Vibrance Money Green in the insert...which will be the color of the car... They call it money green for a good reason...yikes...
    Almost forgot, here is the how the front dropped axle looks in paint too...
  5. Brent, looks like you are making some real progress on the A. Nice work. Pat.
  6. Wow! Holy moly details are awesome! Great work! I'm liking the green/ black, killer contrast.
    -Shiny
  7. Malcolm
    Malcolm
    from Nebraska
    Very nice work -- all of it! That I-beam brace rules.
    Malcolm
  8. Kruzer63
    Kruzer63
    Now as i said before i am a mental case i think as i didnt stop molding everything yet, i did the 9" diffy as well... every bracket, ground smooth, bodyworked the brackets inside and out, had it painted black and then i pinstriped it as well.
    Oh yeah, and i guess i should show you guys the finished product for the ch***is too after all the molding and such i had it shot in a deep gloss black as well. Im pretty happy with it. So when you have a car totally blown apart and you want to still bodywork the body, the ch***is is finished and there is a falcon wagon in the other garage stall what do you do... well this is how you store a ch***is within the stall you are working in too haha... i wont start ***embling it until i can take the body in for paint.
    Now I am on to ***embly of the mill, i only have a couple pics so far but more will come as it gets the shiny parts on it.
  9. Mart
    Mart
    Top notch work.
    Mart.
  10. Boyd Who
    Boyd Who
    Holy ****...nice work!! Can't wait to see this one finished.
  11. Ebert
    Ebert
    from Keller, TX
    REALLY nice! Keep us posted!
  12. hudsoncustom
    hudsoncustom
    ho-lee-****. that's some serious attention to detail.
  13. 64krusty
    64krusty
    I really like the green & black, and ya the PPG Vibrance is $$$$
  14. signal_11
    signal_11
    Agreed. Looks great! :D
  15. Tin Can
    Tin Can
    Looks like it will be a killer car when done. Nice attention to details
  16. Kruzer63
    Kruzer63
    Thanks everyone for the comments.
    kustumkulture1951 i just checked out your build as well, i like your taste... A sedan, Green, black ch***is...etc...nice!!
  17. -Brent-
    -Brent-
    More!!! Love the mount brace!
  18. al-uminum
    al-uminum
    Look's great.
    Really like the attn. to detail.
    I've heard for years theres a guy in SASK who has old Buick's (parts)
    Anyone know anything about it?
  19. willysguy
    willysguy
    from Canada
    Looks good, should be great when done!
  20. LeadSledMerc
    LeadSledMerc
    Hey Brent, I thought you said you had made some progress? HAHAHA
    It's lookin awesome, man. I always thought you were out of control, now I know for sure!! I love how the colors are going to work together, and all that detail work you've been doing for soooooo long is paying off in spades...it's awesome, bud!!:cool:
    Quite the whining about us inquiring minds, and keep the updates coming...please!:D
    Oh yea, nice stripping job!
  21. Spedley
    Spedley
    Hey Brent... Lookin ****in great... I'm workin in the Vag right now, commuting lots, so I'm now gonna be able to come by much easier... I gotta check this out!
    Al-luminum.... I go by that place a fair bit when I'm workin... Ya theres a lot of stuff there, but I have never actually been in the yard... Dont know the people. Some other HAMBers know more abt it than me.
  22. Kruzer63
    Kruzer63
    What are you talkin about here?? Im lost
  23. muddpile
    muddpile
    from Canada
    Well hot damn, certainly is shiny isn't it? I remember when the ch***is was just, well, just a ch***is and the engine was, well, an old engine. Looks pretty amazing now. It's almost too nice to drive, but then it wouldn't be a hot rod would it?
  24. ken1939
    ken1939
    Tell you what, I dunno if I like he project as its progressing, the attention to detail (engine mount is sweet) or the finished project.
    OUTSTANDING WORK!
    Id tip my hat if I had one :)
  25. Kustom7777
    Kustom7777
    from Austin, TX
    its the little details that separate a nice car from an outstanding car,,,,,,and that car is OUTSTANDING......
  26. poorboy
    poorboy
  27. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    Damn!!! How many hours you got in it just polishin?
    That is some attention to detail!
    Can't wait to see it when it's all together.
  28. power58
    power58
    Super Build. Pontiac Engines are my favorite. Glad you picked the OHC Pontiac 6 . Very nice work. Thanks for Posting.
  29. dirtbag13
    dirtbag13
    very nice work , i share the same sickness for pollishing anything that can be , i feel your pain , outstanding fab work !
