Projects Can't afford a 32 3 window, make one.
Discussion in 'The Hokey Ass Message Board' started by Hot Turkey, Jan 11, 2009.
  1. Hot Turkey
    Hot Turkey
    I don't like gl*** but can't afford the real thing or a 25k brookville. So I'm going to try to build one. I bought a brookville firewall, dash and grill shell to help the gl*** body look a little better.[​IMG][​IMG] The feet needed to be trimmed a bit, I put them up that way to get a measurement.
    LOU WELLS likes this.
  2. Royalshifter
    Royalshifter
    Moderator
    What else can you do when the steel ones are so ****ing rediculously priced......there I said it.......go for it man!!!
    hotrodtodd1960 and dearjose like this.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Whose body is that? I noticed the lack of footboards in the floors of 'gl*** 32 3Ws and wondered if they all have those crazy flat floors all the way to the firewall, and that weasely little turn at the base of the firewall doesn't count as a functional footboard, that's for sure.
  4. moter
    moter
    Looks good! Looking forward to more pics.
  5. HomemadeHardtop57
    HomemadeHardtop57
    good idea to get the firewall, and build it right..your way. cuznbrucie on here has a really nice gl*** 32 that he did a fantastic job with.
  6. Hot Turkey
    Hot Turkey
    The body is from Bad *** out of GA. Not the best but Damn good. As for the floor, it ****s! I had to cut the front out and make my own, more pics soon.
    I went with American stamping rails.
    My little girl Shelby loves to turn the ratchet. Can you tell I'm a ford guy?
  7. Hot Turkey
    Hot Turkey
    Using a Bell for the front, the rest of it's all old stuff.
  8. Royalshifter
    Royalshifter
    Moderator
    Good for you getting your children involved.....beats the hell out of TV.
  9. x2 well said
  10. ss34coupe
    ss34coupe
    looks great! I like your idea of mixing the metal parts with the fibergl*** body. Let's face it, metal bodies are rare and expensive - just try to buy one from a guy whose got it stashed away - there are no bargains in deuce land anymore.
  11. Hot Turkey
    Hot Turkey
    I have never done this before so I'm getting great help from Rumbler Del. It's not like my old ford falcon or mustang. I really dig this old junk! It's taken a few years but I'm starting to get it now. I like all the fabin and making parts fit. Now when I go to show and see all the 32s with the billet, I can say "it's all wrong!"
    Got this 302 for free, it had low oil pressure.
    deathrowdave likes this.
  12. hot-rod 33
    hot-rod 33
    you can put a louverd skin over the trunk lid
  13. Hot Turkey
    Hot Turkey
    Now it's 40 over. I put 351 head on it to.
  14. I SMELL SMOKE
    I SMELL SMOKE
    ill be interested to see this build. are you going to build the frame your self? good luck and nice helper
  15. Tony
    Tony
    Did the same thing back in '98..Bought a gl*** 3 window body and built me a hot rod.
    NO way i could afford tin either..And ya know, i had a blast with it!
    I like the firewall idea. Another nice thing about the body your working with is it look's like you can use a stock window frame too, chopped of course, but that add's a lot to the overall look of the car.
    Mine was the same way. I bought a frame from Speedway, chopped it and had it chromed..
    Very cool project, best of luck with it and keep us posted.
    Tony.
    PS: your daughter's a little cutie! :)
  16. Hot Turkey
    Hot Turkey
    I am going to do it all. I started this build last year, I run a lawn busn. and have no time in the summer to work on it. Now I'm working my *** off to get it done. Lots more pics to catch you up to where I'm at.
  17. Hot Turkey
    Hot Turkey
    The frame was a *****! Live and learn.... I know now that you jig it before you box it! It was out of wack a bit but I was able to get it back into shape. Just took many hours to do it right.
    woodz likes this.
  18. kustombuilder
    kustombuilder
    from Novi, MI
    i figured as much when i saw you using a crescent wrench rather than a boxed end wrench. ...oh, you ment cause of your daughters name! :D ;)
    ...good goin. if you realy want to go all out in making it look like a steel car you could put in a cowl vent, pop out windshield and add that feature line around the windshield opening that all the gl*** 32s seem to be lacking. check out some of the old posts Nick32vick put up when he did all of that on his fibergl*** Vicky. you could'nt hardly tell it was a gl*** car till you REALY looked. fooled alot of people.
    i realy like the Brookville firewall in there. nice job.
    Clay Belt and elcamino59 like this.
  19. Hot Turkey
    Hot Turkey
    The front cross member is from speedway and the rear is a 34 I got from Rumbler Del. I got a kit for the center at the Daytona Turkey rod show. It was all out of wack and took a sledge hammer to get it in right.[​IMG]
  20. Hot Turkey
    Hot Turkey
    I got a steering box out of a 52 ford truck, cleaned it up and put it in. I had to grind off the bolt mounts on it so it's welded to the frame on the inside. I cut out the boxing plate and rewelded it around the body of the box.
  21. Hot Turkey
    Hot Turkey
    I'm using 36 rear wishbones I also got from Rumbler Del for the back. I cut off the ends to use as mounting points.
    [​IMG][​IMG]
    -Brent- likes this.
  22. Royalshifter
    Royalshifter
    Moderator
  23. Hot Turkey
    Hot Turkey
  24. Looks awesome so far! Keep it up...
  25. lockwoodkustoms
    lockwoodkustoms
    Now this is Hot Rodding! Like Royal Shifter said, ..Go......... man............ go...
  26. Hot Turkey
    Hot Turkey
    Going with 4:11 gears with an AOD. I had to cut the front wishbones to get them up to the frame. You can see that the steering box has no bolts through the frame.
    [​IMG][​IMG][​IMG]
  27. mid-cal193
    mid-cal193
    looks great, and you have good help, cant beat that. i've got a 5 yr old that i cant keep out of the garage too! good luck to ya and keep us updated w/pics
  28. Hot Turkey
    Hot Turkey
    Now the dash looks cool, much better than the gl*** one but the ends are open. Had to fill them.[​IMG][​IMG][​IMG]
  29. sawzall
    sawzall
    you could have taken the "V" out of the wishbones from the top down!!!
    1946caddy likes this.
  30. rick finch
    rick finch
    Gl***, so what, it will still be a HOT ROD!! Nice build so far, I like it!;)
