Good Sandblaster
Discussion in 'The Hokey Ass Message Board' started by R. Seghi, Jan 15, 2009.
  1. R. Seghi
    R. Seghi
    I'm going to attempt to start ***embly of my 1957 Nomad. To do that I will need to sandblast my firewall and frame. does anybody know of a good inexpensive brand? Or maybe you have one for sale? Not Harbor Frieght. As I have already made the mistake of using their blaster. I need a hand held model. Thx
    Robert
  2. bobss396
    bobss396
    You could rent one for a day, they're reasonable enough.
    Bob
  3. 51 MERC-CT
    51 MERC-CT
    Most sand blasters are only as good as the air supply or air compressor used to operate them.:)
  4. chopolds
    chopolds
    from howell, nj
    I've got the cheapo Harbor Freight one, I use it only occasionally. I've replaced the "sand mixing valve" to a better one, the original wore out quickly. Other than that, it performs well for what it is. It sure comes in handy when you need one.
  5. mow too much
    mow too much
    I agree it's more important to have a large supply of dry air.
  6. sandblaster
    sandblaster
    i'm the best sandblaster ever made but i'm in north carolina. build yourself a pressure blaster from a gas cylinder turned upside down. thats how i got started in sandblasting 23 years ago.
  7. Chaz
    Chaz
    You need a good compressor... able to hold 135 lbs of pressure or so at about 15 cfm. That's usually 7-10 HP.
    Get a pressure feed gun. NOT A SIPHON TYPE!!!
    Then blast away!
  8. budd
    budd
    i'd go to a truck repair shop and ask who in the area sand blasts and paints flat deck trailers, they usely have as good a setup as your going to find, the sandblaster i use to run to do trailers would blast a car frame as fast as you could walk around almost. cut through a 2x4 like a laser.
  9. Rande
    Rande
    If you have to do blasting at home, borrow or rent another compressor and simply ***emble a T fitting and plug both compressors together for increased air supply. Three is better.
    Done it, works great. No huge expense, no towing the vehicle across town. Its just that any home blaster is going to be relatively small and time consuming. Spread a tarp, use some window screen over a 5 gallon bucket to sift the media and re-use it.
  10. the-rodster
    the-rodster
    My $99 blaster from TSC does a fine job with my 5HP Craftsman compressor.
    Rich
  11. Do a search here for PA Blaster. I am building one at the moment. Fiddy has used em and says the rock.
  12. Sealed Power
    Sealed Power
    from TN
    Don't know if there is such a thing as a good inexpensive one.
    ALC makes good ones. Might be more than you want to spend, if you're just going to use it every once in a while.
    They used to make a smaller one which is what I have. I think it holds 35-50 lbs of sand. It's good for fast jobs, would be good for your firewall but it's really to small for doing frames or bigger parts.
    I used it to do a truck frame once it took a long time, spent more time puttin' sand in it than I did blasting. :rolleyes:
    Here's a 90 lb one. It would work better for bigger jobs.
    I would suggest finding someone local in the sandblast business for big items. That's what I do now. They usually do it cheaper than I can buy the sand.
    http://www.acme-tools.com/product/4070/
  13. Get a good compressor. Keep the sand dry. Moist sand sux. After youve done the firewall, and frame, get a cbinet to do small pieces. Mikey
  14. dabirdguy
    dabirdguy
    I've built a cabinet for blasting. I need the gloves. Any idea where to get them?
  15. budd
    budd
    i made my own gloves, i bought a good pair of rubber gloves and a new pair of ladies leather motorcycle pants from value village, still had the tags on them, cut the legs off and sewed the gloves on, the vinyl ones you pay $100 for dont last very long. it cost me about $30 for mine.
  16. Sealed Power
    Sealed Power
    from TN
  17. dabirdguy
    dabirdguy
    COOL!
    Thanks!!
