"TECH MONTH SMACKDOWN".... time to decide the WINNER!
Discussion in 'The Hokey Ass Message Board' started by wingnutz, Jan 16, 2009.
  1. Tech Month Submission: Novel Slimline Column Drop:
    1.9%
  2. Tech Month CHEAP and EASY Steering column (under $20)
    3.7%
  3. Tech: (simple) Olds water crossover
    1.0%
  4. caveman tech II - rebuilding your cowl top from scrap
    2.8%
  5. Hot Rod Institute 33 Chevy PU Chain Steer
    0.7%
  6. Caveman tech - building a bellhousing for a flathead cadillac
    14.7%
  7. **TECH** door buttons on the cheap
    0.2%
  8. Tech small rod and tubing bender
    0.9%
  9. Tech Month:Reaming Spindles CHEAP
    0.2%
  10. tricky patch panel fabrication and installation
    1.2%
  11. TECH MONTH: Stepping lower A arms
    0.9%
  12. cutting down a backglass
    1.9%
  13. TECH : Buick Ventilation Motor Swap
    0 vote(s)
    0.0%
  14. 1951 Buick Frenched my Headlights / Tech...
    0.9%
  15. How to Reface/Replace Your Own Gauges
    1.2%
  16. Build a heat shield - cheap.
    0 vote(s)
    0.0%
  17. Triangulated rear suspension under a 46 Ford
    0.2%
  18. 1951 Buick Fan Shroud / Tech...
    0.2%
  19. TECH: Installing 54 Mercury taillight lenses into your kustom
    1.0%
  20. buick drums on the cheap!!! well, sorta...
    1.2%
  21. How to splice wires
    1.6%
  22. Tech Month: 11 tooth chrome grille for under $150
    1.9%
  23. Old school chevy electronic ignition
    6.6%
  24. Hemi Tech, 392 Dist swap to 331-354
    0 vote(s)
    0.0%
  25. Tech Month~~Home made metal shaping tools
    16.3%
  26. Custom Taillights (tech week)
    0 vote(s)
    0.0%
  27. Tech: Real easy, real cheap tail light gasket.
    0 vote(s)
    0.0%
  28. Tech: Scratch build References
    0.2%
  29. Remove early Ford drums with home made puller
    0.3%
  30. Tech- The Ultimate Engine Stand:
    1.4%
  31. Tech: How to salvage your original, rusty gas tank
    0.5%
  32. TECH: Making a LWB to a SWB - cutting a '55 - '59 Chevy Truck Frame
    0.5%
  33. 1951 Ford Truck Project Pics - (Lowering The F1)
    1.0%
  34. Quick tech Poor mans dimple die
    0.3%
  35. Tech:Falcon-Comet-Ranchero-Chevy II Nova Roller Bearing Spring Perches
    0.3%
  36. ***Homemade 32 Grille Insert Tech****
    0.5%
  37. Putting a 32 Header in a 31 Model A w/Lots of Pics
    3.8%
  38. Leatherback to Steelback – Vicky's Got Curves In All The Right Places...
    0.3%
  39. Tech Month Low Buck Nailhead solid motor mounts
    0.5%
  40. Model A Ford Center Steering Box
    0.2%
  41. Model T Rear Safety Hubs
    0 vote(s)
    0.0%
  42. Lowering the of the Model T Ford
    0 vote(s)
    0.0%
  43. TECH new boards for old door panels
    0.7%
  44. Low buck, home built dual plane HEMI intake
    6.5%
  45. ‘52 F-3 build-up with a few tech mods.
    1.0%
  46. DIY Open Drive Banjo Conversion
    3.5%
  47. Hard to remove screws Removal
    0.5%
  48. Tech: Cheap Roadster Top
    2.8%
  49. Self Storing, Self Locking Hood Prop
    0.2%
  50. TECH - Filling trim holes.. EASIEST CHEAPEST WAY
    0.2%
  51. Tech: Piston Shifter Knob How To:
    0.2%
  52. **TECH** How to make a banjo steering wheel!
    3.3%
  53. AIR RIDE on early GM IFS
    0.2%
  54. $12 HOOD BLISTERS to hide your HEMI
    2.6%
  55. A different way of mounting a 3 piece hood
    0.3%
  56. Laying out LOUVERS the easy way.
    0.2%
  57. Tech Submission: The dreaded bumpsteer.
    0.5%
  58. TECH - EASY way to Section, chop, pancake a 50's hood
    0.5%
  59. TECH - Electric Wipers
    1.9%
  60. TECH: Bench Seat Build
    2.8%
  61. TECH: Making gaskets, cheap and easy
    0.7%
  1. Well here it is... the final moment of the "Tech Month Smackdown" winner take all vote thread!!!!:cool:
    This Poll will be posted for 5 days Only so that 65,000 members have a good chance of voting!!!
    I want to remind you fellas and Gals to reveiw all threads and vote for the "Best" tech thread presented this past month.
    You only get one VOTE so make it count because there are many fine quality threads but only one "WINNER"...!
    There are 61 threads and this will be tough vote and I Thank all the people for their submissions and all the positive feedback.... because they are all winners...!!!
    by: Mart
    by: choppintops
    by: Paul
    caveman tech II - rebuilding your cowl top from s****
    by: zibo
    Hot Rod Ins***ute 33 Chevy PU Chain Steer
    by: HRV03
    by: zibo
    **TECH** door ****ons on the cheap
    by: AstroZombie
    by: rodknocker
    by: choppintops
    by: kustombuilder
    by: droplord49
    cutting down a backgl***
    by: NONAME
    by: nailheadroadster
    by: tylerdurben
    by: valkokir
    by: chop&drop
    by: oldspert
    by: tylerdurben
    by: Ether
    by: negativeMatt
    How to splice wires
    by: plym49
    by: 1949windsor
    by: GMC BUBBA
    by: Gkafer
    by: jhnarial
    by: blown240
    by: johnboy13
    by: Jalopy-Phil
    by: INXS
    by: Drive Em
    by: Tumbler
    by: 53choptop
    by: Scott in Missouri
    by: Nocero
    by: Drive Em
    by: 6deucecaddy
    by: DRuss32
    by: DRuss32
    by: Lobucrod
    by: daredevilcustoms
    by: Squablow
    by: kustombuilder
    by: '52 F-3
    by: Tman
    by: Anarchy Choppers
    by: fergenboysinc
    by: C9
    by: southpark
    by: Drive Em
    Strawshop Opendrive Banjo Conversion DIY
    by: Tman
    by: oldrelics
    by: kustombuilder
    by: kustombuilder
    by: kustombuilder
    by: kustombuilder
    by: Mart
    southpark
    by: Flat Ernie
    TudorChevy
    by: Dreadman
  2. choppintops
    choppintops
    So, how do you vote?
  3. K13
    K13
    Click on one of the little circles beside your favorite post at the top and then hit Vote Now
  4. choppintops
    choppintops
    I had posted before he made the poll. :D
  5. lindross
    lindross
    Wow! That's a ****load of great info for a young brain to absorb. :D Don't take a rocket scientist to figure where my vote goes. Bubba is the man and knows his ****!
  6. Pir8Darryl
    Pir8Darryl
    Awwwwwwww fudge!
    This one is gonna be hella-tough. I'm pretty sure I got it narrowed down to 3, but I cant decide from there.... Maybe I should deduct points for spelling and punctuation to help narrow down my decision??? :D
    Best of luck to EVERYONE!
    P.S.
    I'm working on a big one that may actually be a contender for the next tech week/month/smackdown... Any idea when that might be?
  7. Pir8Darryl
    Pir8Darryl
    The HAMB's annual "cabin fever" tech smackdown... I seriously like that idea!
    I think it should run from Jan 1st to the 31st, as the month of Jan seems to be the darkest part of winter. That also gives us a whole year to plan for it.
  8. choppintops
    choppintops
    I know, we had to suffer through a high of only 72 here yesterday. :D
  9. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Sure was tough to pick just one.............. geez!
    Lots of great tech out there, I have some in the works for next time.
  10. Pir8Darryl
    Pir8Darryl
    Kiss my boo-tox 'ya turkey. The heater has been running full blast here for 3 days now and it wont even get up to 68* inside the house! :eek:
    Arizona.... 72... Hmmm... So how's the job market out there? :D
  11. choppintops
    choppintops
    Job market isn't even near as hot as the weather, thats for sure. Funny thing about the temperature, I don't remember ANYONE saying they wanted to come out when we hit 128 degrees that one year. :D
  12. 35 Dodge Hot Rod
    35 Dodge Hot Rod
    from Mecca
    What I don't understand is how "Old school chevy electronic ignition" could possibly be tied with "Caveman tech - building a bellhousing for a flathead cadillac".
    There is no comparison.
  13. Pir8Darryl
    Pir8Darryl
    The results this early in the game mean absolutely nothing. A mere 104 people have voted out of the 64,000 hamb members.
    They are both excellent threads, as well as two of my favorites.
    Vote for the one that "speaks to you" the most, simple as that.
  14. tough call they are all winners in my book .. good luck to everyone..
  15. Glen
    Glen
    Thanks to all those that contributed....I will send my $50.00 donation straight to the winner after wingnutz wraps up the poll.
  16. choppintops
    choppintops
    No kidding. These people took the time to take pictures and write posts to share a wealth of information. If you read through them and learned ANYTHING AT ALL, even a tiny tip, then show them that their efforts were not in vain, by at least taking 20 seconds to vote. :cool:
  17. hscott
    hscott
    Tough decision, think I'll put 3 # in the hat and pull a number. Great job for all that took the time with picture to post. In time I'm sure all the tech will used by another member. Scott
  18. Squablow
    Squablow
    I thought about it for a while and I was trying to decide between Caveman tech and the pie cut hood. I went with the hood because after reading it, I'm confident I could do that, where as after reading the other I'm confident there's no way I could pull that off. I'll give honorable mention to the custom banjo wheel which I also thought was cool.
  19. Pir8Darryl
    Pir8Darryl
    That's beautifull man!
    I still cant decide. I'v got it narrowed down to 4, and I keep reding them over and over trying to find "the one", but there all just so damn good.
  20. I didn't realize "How Hard" it would be to vote... I narrowed it down by the equipment I have or would use.
    Next I narrowed it down by my willingness to perform the action or make the part.
    Then I write down the remaining 20+ threads on "playing cards" which I attatch to a "Bicycle wheel" then I give it a spin and when the wheel stops I select the card on the closest spoke to the Crank hub as the "WINNER"...!
    So don't blame me on my selection... "Blame it on the Draw of the Cards"!!!!
  21. Paul
    Paul
    Editor
    the choice was simple for me,
    same as every election,
    if I put myself in the running
    I vote for myself..
    that way I always get at least one vote :p
  22. 1949windsor
    1949windsor
    I posted a tech for this contest but after looking around at everything available here I should have made it short and sweet:
    1. First log on to:
    http://www.jalopyjournal.com/forum
    2. Then so a search for what you need (see picture below)
    3. If you did not find what you need post a thread and say:
    4. Within minutes you will have the answer you are looking for and probably 5 different ways of accomplishing what you needed to get done, where to buy it, and what not to do.
    I am not even trying to kiss ***. This place has some of the most well read and giving people I have ever met. I know that lots of the guys on here give advice every day for free.....and take money right out of their own pockets. These guys make a living doing metal work, body work, paint, auto repair, etc. and its there experience and know how that feeds there kids. They are on here answering questions and helping others for the love of old cars.
    The reality is that the best tech thread ever goes to the guys who started this place and everyone who comes here to contribute! I am working on a car right now and I think I have been on here at least twice a day for the past 4 months getting help and I just wanted to say thanks to every one!
    Brandon
  23. Hot Rod Michelle
    Hot Rod Michelle
    Wow! So much good tech info here that even a dummy like me could figure out how to build something.
  24. This is ****** great! Tech week just gets better and better, I seriously love this place.
    Doc.
    Yes Darryl I DID vote.....
  25. tiresmoke!
    tiresmoke!
    My vote's in place as well.......the Old-school Chevy ignition deal just makes so much sense......as does all of the tech articles, for that matter.
    Bubba, if I ever hit the lottery and have spare time galore, I'm knockin' on yer door for an apprenticeship!
  26. careyohio
    careyohio
    Thanks and hats off to all who took the time to share...The " Old Dog " learned a thing or two. Tough to pick just one.
    Carey
  27. Kustm52
    Kustm52
    Can we get one of those cool "I voted" stickers they always give you at the polls?:D
  28. Difficult choice. Strangely, some really good ones got no votes at all. I voted on one I most likely will be using; no way I could narrow down the BEST one..
  29. Flat Ernie
    Flat Ernie
    Tech Editor
    These are just the primaries, right? After this comes the run-off... ;) :D
  30. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Man, some have zero votes. You'd think the guy who wrote the tech would have at least voted for himself! Ha.
    But serious let's get some more people voting here, this is why we all come to this site to read and learn. let's show those who share thier ideas and hard work with us that we appreciate it!
