Features Good or bad let us see pictures of your F1 or F100!!!!
Discussion in 'The Hokey Ass Message Board' started by 56fordf100, Dec 16, 2008.
  1. 56fordf100
    56fordf100
    from Arkansas
    Found this one on ebay today nice!
  2. 56fordf100
    56fordf100
    from Arkansas
    Lets talk camaro clips and chevy 5 on 5 pickup rear ends. Has anyone ever put this combo under there 53 to 56. Is the pickup rear end to wide. Can you make the 5 on 5 pickup rotors go on camaro spindals. The reason I ask is I already have a camaro clip under my 56. I would like to have a 5 on 5 pre 88 chevy pickup bolt pattern with out using a wheel adopter. The other reason I ask is I already have a lot of chevy pickup parts. Thanks for any help
  3. I dig it!
  4. hoop
    hoop
    I have a Trans Am clip on my 56,same as Camaro. I used Oldsmobile Custom Cruiser spindles direct swap and 5 on 5 bolt pattern.
  5. havi
    havi
    I am no GM expert (I leave that nonsense to my brother), but Impalas from 1971-76 seem to have a 5x5 pattern, as well as 2wd chevy trucks. The popular 57-72 Ford truck swap is 61.25", so anything close to that width should be good. The stock frame width for spring pads is 40" on center.
    58" axle width is probably going to be too narrow, unless you tub the bed. Should give ya ballpark numbers anyhow.
  6. henryj429
    henryj429
  7. 57 cut up
    57 cut up
    from dixon ca.
    its last day as an original.
  8. Frosty21
    Frosty21
    from KY
    Before:[​IMG]
    After:[​IMG]
    $100 Cannabalized RUSTY parts-truck, trying to get it done for spring.
  9. Carbs & Chrome
    Carbs & Chrome
  10. Carbs & Chrome
    Carbs & Chrome
  11. Carbs & Chrome
    Carbs & Chrome
  12. Carbs & Chrome
    Carbs & Chrome
  13. Carbs & Chrome
    Carbs & Chrome
  14. Carbs & Chrome
    Carbs & Chrome
  15. Carbs & Chrome
    Carbs & Chrome
  16. Carbs & Chrome
    Carbs & Chrome
  17. Carbs & Chrome
    Carbs & Chrome
    And since I've seen some bigger rollers and stuff posted:
  18. Carbs & Chrome
    Carbs & Chrome
  19. Carbs & Chrome
    Carbs & Chrome
  20. Carbs & Chrome
    Carbs & Chrome
  21. Carbs & Chrome
    Carbs & Chrome
  22. Michigan Rick
    Michigan Rick
    from Owosso Mi.
    here's a friends partial collection...
  23. Carbs & Chrome
    Carbs & Chrome
  24. Carbs & Chrome
    Carbs & Chrome
  25. maw4805
    maw4805
    Here's My 53!
  26. Carbs & Chrome
    Carbs & Chrome
  27. Michigan Rick
    Michigan Rick
    from Owosso Mi.
    maybe this...friends collection from Swift Engineering...Ontario Ca.
  28. Carbs & Chrome
    Carbs & Chrome
  29. Carbs & Chrome
    Carbs & Chrome
  30. Carbs & Chrome
    Carbs & Chrome
