Customs Will 1950 4 door 1/4s fit a 1951 2 door?
Discussion in 'The Hokey Ass Message Board' started by SAN JOSE MIKE, Jan 21, 2009.
  1. SAN JOSE MIKE
    SAN JOSE MIKE
    from SAN JOSE
    Has anyone ever seen or heard of anyone ever using 49/50 Merc sedan rear 1/4s on a 51 two door Merc.I have a 50 four door parts car and would like to fab the 1/4s onto my 51 if possible.Thanks in advance for any info.
  2. hotrod-Linkin
    hotrod-Linkin
    buick?chevy?ford? mercedes????
  3. Squablow
    Squablow
    Are you just talking about the lower quarter panels, the pieces that bolt on, or are you talking about the whole rear clip?
    You could graft a '50 rear clip onto a '51 if you didn't like the '51 extended quarters, I'm sure it'd be a bit of work but it could be done (personally I like the '51 quarters better but I could be in the minority).
    If you're just talking about using the lower rear quarters, they'd be a lot of work since the forward part would be missing on the 4 door quarters, and the rear part is different on a '51.
  4. SAN JOSE MIKE
    SAN JOSE MIKE
    from SAN JOSE
    I am talking about the rear 1/4s not the bolted on ones.
  5. Squablow
    Squablow
    So you basically want to graft on the whole rear clip. Yeah, I'm sure it'd be do-able, I think the trunklids are the same, you'll want to brace the **** out of the car before you start cutting.
    I guess the important part would be if the trunk pan and rear framerail area is the same (I'm not sure if it is or not) because if it is it shouldn't be all that difficult, you could separate the trunkpan from the quarters by cutting all the spot welds out and make your vertical cuts right below the back window.
  6. SAN JOSE MIKE
    SAN JOSE MIKE
    from SAN JOSE
    Yea, it looks like a lot of work.I was hoping someone had did one and had some pics.Thanks for your time.
