chevy 235
Discussion in 'The Hokey Ass Message Board' started by aktattoo, Jan 22, 2009.
  1. aktattoo
    aktattoo
    so I just found this 54 235 motor fully rebuilt on craigslist, It seems the guy I bought it from changed his mind and wanted to go with a v-8, must II, ect. He told me that the motor had never been fired but it was sitting in his garage for a very long time like 5 years . So I picked it up brought it home took it apart and It was a freshly rebuilt motor never fired. I took the head, oil pan,side cover off and inspected it very carefully and the only thing I could find is that the motor was very tight!!! I could barely turn the crank shaft over with a pry bar. I plastigauged all the mains and were all @ .001 Do engine bearings go bad from sitting? Is there anything I'm overlooking or is that just normal for an engine thats been sitting???
  2. hotrod-Linkin
    hotrod-Linkin
    normal..check the valves and springs,,they do get weak from sitting in one spot.you should have oiled the cylinders before turning.
  3. old dirt tracker
    old dirt tracker
    from phoenix
    if you have the plugs out the engine should turn over fairly easy. if not keep looking, maybe pull the head and see if the cyls have surface rust.
  4. bigedpa
    bigedpa
    rings will get moisture down to them and lock to the cylinder walls. especially if the engine was not ***embled w/a sufficient amount of ***embly lube or other lubricant. if you think this is the case, try soaking the cylinders in ****** fluid and brake fluid. i don't remember the proportions, but i am sure some one here knows them.
    big ed
  5. 302GMC
    302GMC
    from Idaho
    I'd be checking the ring end gaps. Never trust anything somebody else put together.
  6. S.Sutherland
    S.Sutherland
    from Fontana,CA
    Is it just tight or does it stop at the same spot every time... I installed a cam wrong on one of these once and it went one way, then the other, but both times stopped at the same exact spot. Easy to fix if you catch it while turning it by hand.
    Good luck.
    Seth
  7. yorgatron
    yorgatron
    i sent you a PM,i have a 235 for sale in San Jose.
  8. Snarl
    Snarl
    A fresh rear main rope seal can require at least 50ft/lbs on a breaker bar to turn over. If you were to loosen the rear main journal, that would tell you if it's that or something else...
