Chevrolet 235 spin on oil filter
Discussion in 'The Hokey Ass Message Board' started by old1946truck, Jan 25, 2009.
  1. old1946truck
    old1946truck
    I've heard about spin on oil filters for chevy 235's does anybody know where to get one?
  2. Speedwagen
    Speedwagen
  3. 6inarow
    6inarow
    Transdapt part number 1075
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    Be advised there is no good reason to use the spin on style other than a bit easier to change. You MUST have a .062 restrictor fitting in the supply line to the filter no matter what style you use. Without the restrictor your oil pressure will be very low as these engines were set up for byp*** filters only other than 58 up 261 truck engines.
  5. old1946truck
    old1946truck
    Where can I find one of these restrictors at?
  6. Or just go straight to obrien truckers, hamb alliance discount.
  7. old1946truck
    old1946truck
    All I need is the .062 restrictor fitting and does anybody know where I can find filters for the GM canister type filters at? But those obrien filters are cool just dont have the cash.
  8. Kustm52
    Kustm52
    If you are talking the original canister filters you can get them at any NAPA FIL 1100.
    Brian
  9. 6inarow
    6inarow
    Maybe you 2 guys are talking about 2 different things.
    1946truck, do you want to convert to full flow oil? what year 235? JohnEvans, if you convert to full flow, you dont need the restrictor.
  10. R Pope
    R Pope
    Spin-on filters don't catch as fine of **** as the can type made for a byp*** system. Leave the thing alone!
  11. old1946truck
    old1946truck
    Its a 1955 Chevy 235 out of a car.
  12. You can take the aluminum filter adapter from a FE ford. They can be easily used for remote filter adapters. Make a plate for the back and drill and tap for hose fittings.
  13. JohnEvans
    JohnEvans
    from Phoenix AZ
    The restrictor fitting is a Weatherhead # 1512. You can make one by soldering a aproperate fitting closed and drilling a 1/16 hole through it.
    6 in a row : I'm well aware that a fullflow system does NOT need a restrictor. Also unless the engine is a late 261 which the one here isn't some farily involved mods are needed. Not too hard to do if the engine is out of the car and to do correctly striped.
    As said earlier the byp*** filters do remove smaller particles but only 10% of the oil is going through the filter at anyone time. Put lots of miles on Chevy 6s stock to modified late 50s early 60s.
  14. roddinron
    roddinron
  15. old1946truck
    old1946truck
    Ok I'm still thinking about the sin on filter. But where can I still get filters for a fram canister? And whats the number on them?
  16. Deziner2002
    Deziner2002
    I have a '59 3200 truck with a 235. The oil canister is mounted behind the carb on the intake but the flex lines were rotten when I got it. Any idea where I can get new flex lines or are there any other ideas? I would like to keep the canister and not use a spin-on.
