Anyone use Chassis Eng. suspension kits for 49-54 chevy????
Discussion in 'The Hokey Ass Message Board' started by alteredpilot, Jan 27, 2009.
  1. Saw the article in R&C about the ch***is engineering truck arm rear suspension set up for the 49-54 chevy, but there is no info in the online catalog and i get nothing but busy signals on the phone...
    I'm also looking into the bolt-in pinto/mustang IFS front end for the same.
    anyone have any feedback, experience, input, or otherwise to share???
  2. Jack & Danny
    Jack & Danny
    That rear suspension was from Cl***ic Performance Products in California, not Ch***is Engineering, though the front suspension is theirs.
  3. that would explain my difficulty....
    thanks.
    any feedback on the CPP kit?
  4. hotdamn
    hotdamn
    I have a 54 with posies 3 inch drop springs in the back and a fatmans MII kit in the front.
    the posies kit I am more than happy with. just keep in mind your center pin locator's.
    meaning that if you are running a stock rear get the springs that work with them,
    if you are getting a late model rear get the according springs...
    if you call posies they can walk you through all that.
    as for the fatmans crossmember kit, I love mine, I have the basic ultra low kit with a manual rack and I am tickled pink:)
    it is not hard to install so as you can do basic fab work and can weld.
    I would personally stray away from a bolt in kit.
    b/c you have to
    A: put in a cross member and
    B: put tops on the frame (upper spring buckets and A arm mounts)
    these are items I personally want welded into my car.
    the cool thing is that you can keep your stock column too, with just a little bit of work.
    it is however way easier to do so if you are not keeping the 3 on the tree...
    hope this helps a little.
