216ci got issues and need help
Discussion in 'The Hokey Ass Message Board' started by KustomRust, Jan 19, 2009.
  1. KustomRust
    KustomRust
    Got an issue with the 216 (straight six) in my 52 chevy. I am getting a constant hesitation when I drive the car. It's just a **** load of hoping and poping. I started out with the carb and noticed the amount of rust...so I got a new tank (tank was a mess) and blew the lines out....also took carb apart and did some cleaning (not a complete rebuild). I drove the car a few miles and then it was back to the same hopping and poping....when the car is at rest there is no hesitation...only happens when I put the motor under load. I thought I may have a vacuum leak so I cheacked everywhere...no vacuum leak that I can find. Does any one have advice? I am new to this whole thing and I am not paying somebody to get there hands dirty while I read a Peoples Mag. in the next room....so any suggestions would be appriciated.
  2. henry29
    henry29
    Your fuel pump may be full of junk and the lines my be rusty.
    Do you have an inline fuel filter?
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Make sure that the vacuum advance pod isn't ruptured.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    Remove carb and blow out all p***ages as that seemed to fix it before. Then put a inline filter just ahead of the carb.
  5. 38Chevy454
    38Chevy454
    I think you answered your own question since cleaning things out helped and then it came back. You need to run a good filter right before the carb. Keep a spare in the car as you will need to run it a while to clean out the system fully. It may plug a filter or two before it gets cleaned up.
  6. BISHOP
    BISHOP
    Fuel pump full of ****. Take it apart and clean it up too. All that **** in the carb had to go through the pump to get there.
  7. hotrodscott2003
    hotrodscott2003
    Check all the electrical! Timing could be off, bad wires, loose wires, bad distributor bushing, bad ignition wires...start with the easy stuff and eliminate as you go. If fuel delivery isn't the problem, go with timing first. Does the car have a stock wiring harness? Check there, too. My guess is timing, that's what it sounds like to me. Have fun!
  8. KustomRust
    KustomRust
    Thanks everyone...i will take the list and have at it...if that dont work then i u will see a post that says "F-this 216"
  9. SpiritOf62
    SpiritOf62
    Something that happened to the vacuum tubes in my chevy straight 6 was the PCV was bad, so I replaced that and I didn't get any jolting. Hope it works out.
