46 chevy truck
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by chevy46, Nov 16, 2008.
  1. chevy46
    chevy46
    from ohio
    hello everyone, new on board here. I have a new toy, a 46 chevy truck that needs work. body work that is. I think so far the biggest problem I have with it is the cab pillars are rusted through. is there a company out there that makes a patch paneel for these ? or is this something that will need to be fabricated ?
  2. Black Primer
    Black Primer
    Welcome, I think your on your own with the pillars. Maybe you can chop it and eliminate the bad areas. Another option may be a donor. How are your fabrication skills? Sounds like a good winter project...Good luck.
  3. Have you tried looking like chev's of the 40's,ems,or some of the advertisers in cl***ic trucks,ol skool rodz,rod & custom or stuff like that i have a 33 chev 3 window coupe and 40 chev 2dr sedan
  4. koth
    koth
    Send me a PM, I know of a cab in a junk yard that should work.
  5. kman1932
    kman1932
    Hello and welcome to the HAMB from nw. Pa.
  6. Lucky667
    Lucky667
    from TX
    Hello & Welcome to the HAMB.
    Good Luck with your new career in fabrication.
    Lucky667
