1932 Pickup Build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Mar 27, 2008.
  1. Jeem
    Jeem
    Alliance Vendor
    Would you sell the Michelins you've got on the back? .....oorrrrrrrr, what size are they? I'm looking for the perfect size radial for my truck, the proportions are spot on!!!!
    How tall and what is the section width as well as the tread width....THANKS
    OH. I dig the truck......give it more rake though!
  2. Salt Flats Speed Shop
    from Utah
    I would actually like to sell those tires. I will have to get the measurements later when I get back to the shop.
    Thanks
  3. Salt Flats Speed Shop
    from Utah
    I havent realy been working on the pickup lately. Ive got the 36' 3 window that I am working on durring the day. Then at night and on the weekends I am going to be doing a 32' 5 window and 32' roadster for trade work.
    I got part of my log manifold. So for now I just got the carbs set in place. It totaly changed the look of the car for me.
    <table border="0" width="1024" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzg0LmpwZw%3D%3D" width="1024" height="768"/></td></tr></table>
    <table border="0" width="1024" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzg1LmpwZw%3D%3D" width="1024" height="768"/></td></tr></table>
  4. Crazy Horse
    Crazy Horse
    from Arnold MO
    All I can say is WOW!!!!! *****in truck, love the way it looks man
  5. Southfork
    Southfork
    Looks like you've got several great projects in the works --- or at least in line. Where's your shop at anyway (address)? What are your normal business days/hours? PM me if you want, cause I'd also like to stop by.
  6. Salt Flats Speed Shop
    from Utah
    I worked over the weekend on sanding the metal on the cab. Just trying to get her to shine :) I also got the grill and headlights mocked up.
    <table border="0" width="1024" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzg4LmpwZw%3D%3D" width="1024" height="768"/></td></tr></table>
  7. milkweed
    milkweed
    from SLC UT
    its lookn good maybe i will give you a call and stp bye over the holliday if your going to be around
  8. HotRod33
    HotRod33
    Great looking truck....Do you have a picture of the complete frame......?
  9. Strange Agent
    Strange Agent
    Looks really good.
  10. Salt Flats Speed Shop
    from Utah
    I might, but it will be on my shop couputer. Ill see tomorrow.
  11. original patina
    original patina
    from Texas
    Very much enjoy seeing your progress threads. Do you have a website, myspace, etc. where the bulk of your work can be viewed?
  12. lift that rear a bit...looks to good to be sitting with such a silly stance.
  13. Salt Flats Speed Shop
    from Utah
    I'm currently in the process of re-doing my web site. Hopefully it will be up soon.
  14. Salt Flats Speed Shop
    from Utah
    Thanks, but im not building a muscle car so I prefer it level across the ground.
  15. i was thinking a little rake, not stink bug. still looks nice, so I will forgive you :D
  16. Carb-Otto
    Carb-Otto
    from FINkLAND
    Interesting build, I'll be followin' this!
  17. Salt Flats Speed Shop
    from Utah
    I know I was just joking with ya :) I have played with some rake, and when I lift up the rear end the bed looks wierd, like its to skinny. With these square cabs I realy like them level with the ground but if I was building a 36' truck I would have it on a rake for sure.
  18. kisam
    kisam
    I would like to see some pics of the frame build if you have them?
    Thanks,
    Kathy
  19. Salt Flats Speed Shop
    from Utah
    Here is a picture of the rear section up to under the cab, and the next is of the front.
    I now have lots more bracing in the frame section under the cab.
    My plan is, once I start tearing the pickup down to get things painted, I will weld in lots of gussets all over the frame in all the kick up areas. Just to make sure to take all of the flex out of the frame.
    The frame rails are 1/4" thick exept for the front frame with the holes. I even thought of making a bolt in frame part that runs across the bottom of the arch for the rear kick up. That would remove any spring in that part.
    <table border="0" width="576" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzMyc21hbGwuanBn" width="576" height="432"/></td></tr></table>
    <table border="0" width="640" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzMzLmpwZw%3D%3D" width="640" height="480"/></td></tr></table>
    <table border="0" width="1024" style="border: none; font-family: Myriad, Helvetica, Verdana, sans-serif;"><tr><td colspan="2" style="border: none;"><embed type="application/x-shockwave-flash" wmode="transparent" allowNetworking="all" src="http://w667.photobucket.com/flash/tagWidget.swf?mediaURL=aHR0cDovL2k2NjcucGhvdG9idWNrZXQuY29tL2FsYnVtcy92djM2L1NhbHRfRmxhdHNfU3BlZWRfU2hvcC8xOTMyJTIwU2hvcCUyMFRydWNrLzU4LmpwZw%3D%3D" width="1024" height="768"/></td></tr></table>
  20. Jibs
    Jibs
    I like your choice for the power train, keep the pictures coming. Jjibs
  21. gasser32pickup
    gasser32pickup
    from Australia
    Dude, your pickup looks truely kick***!
    I am currently building a 34 along similar lines.
    Any chance I could ask a m***ive favour and ask for some dimensions of the pickup bed? Just basic length width and depth. I have to make one from scratch, because no one makes them here in Aus and the import freight and duty on the us repo stuff is ridiculous. Feel free to pm me if you dont want the numbers on here.
    Cheers mate.
    Again, looks wickedly *****en!
  22. lodaddyo
    lodaddyo
    man that truck is gonna be coool!
    i love how you did the rear frame rails
    nice job, im looking forward to see this thing finished
    Ryan
  23. sloorider
    sloorider
    After you sand the bare metal, what do you put on to keep it looking the way it is?
    Thanks.
  24. Salt Flats Speed Shop
    from Utah
    I use a product called Gibbs Brand Penetrant. The stuff is amazing, it keeps metal from rusting and it will even keep magnesium from oxidizing. Crazy stuff. Plus once it dries it isnt all sticky like wd40 or other stuff like that.
  25. Skotz
    Skotz
    Turning into one heck of a nice shop truck!!!
    Skot
  26. Johnny C.
    Johnny C.
    Awesome truck. I am building a 34 that has a 3" chop and will have a similar style. Can't wait to see more as you work on it. Nice fab work.
  27. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    this is cool. I likey.
  28. leadsled deluxe
    leadsled deluxe
    Bad *** I love 32 trucks its looking good.
  29. moon man
    moon man
    Nice work, truck looks good.
  30. brentthebarber
    brentthebarber
    great shop truck and build, are the front rails from macs ratz?
