help 40 ford front brake shoe which order?
Discussion in 'The Hokey Ass Message Board' started by HELLMET, Jan 28, 2009.
  1. HELLMET
    HELLMET
    does the long one go in front or rear? help please .billy
  2. Thumper
    Thumper
    short shoe to the front...long shoe in the back.
  3. That's only on Bendix style self energizing brakes.
    On 40 Ford Lougheed style brakes, which are not self energizing the long shoe goes to the front.
    HemiDeuce.
  4. HELLMET
    HELLMET
    thanks hemi deuce . billy
  5. Thumper
    Thumper
    I stand corrected :)
  6. OL 55
    OL 55
    ......and leave yourself plenty of room to stop!:rolleyes::D
  7. Alienbaby17
    Alienbaby17
    Not to be a wise-guy, but this is why we were always taught to only do one side at a time when replacing brake shoes. If you do it that way you can always look at the other side for an example on how to put it back together. I've been a professional mechanic for over 15 years and I still do it that way.
    Jay
  8. HELLMET
    HELLMET
    because its all rebuilt to new and i had nothing to go by. i was just going to run spindle no brakes so i put brakes on the front. i have built this whole car that way. i bead blasted every nut and bolt i did every thing myself. not a shop. so basicaly i started from scratch. billy
  9. ol gasser
    ol gasser
    from here
    I have been a mechanic for 38 years .Take pics when takeing apart and or make diagrams . Saves time and headaches.
  10. I agree that doing one side at a time is the best way. Hopefully the guy before you put it all together the right way...
    Drawing a picture or taking one helps. I draw a little pic of how serpentine belts go before I rip an engine apart.
    I drew a picture of where all the wires went in my TV that I took apart last night too.
    Don't expect to remember how **** goes back together after a few days..or sometimes alot longer. Especially if you are not familiar with it.
    Even more so, if lots of beer consumption is between the dis-***embly and the re-***embly.
    Get yourself a copy of the Green Bible..that will show you how everything mechanical goes together on your car.
    Tons of pics and exploded drawings.
  11. fordcragar
    fordcragar
    from Yakima WA.
    I try to find a picture to check if the guy before me actually did it right, just to make sure; but still only do one side at a time.
  12. mike c
    mike c
    I am in the process of doing the same to a 40 ford brake setup. I agree that the big shoe goes to the front and the large end of the wheel cylinder also goes to the front.
  13. Model A Mark
    Model A Mark
    from dallas
    hey hellmet, i got this a couple years ago and its the best brake adjusting guide ive ever came across for 40 style brakes.
    this is how i set mine and my ol car stops on a dime and tosses yu back 9 cents.
    good luck, hope this helps yu ..
    elwood ..
    The following applies to 39-42 Ford/Merc
    brakes with adjustable lower shoe anchors:
    The system must have good master cylinder and
    wheel cylinders that do not leak, drums must
    be machined so that they are smooth and
    round. The master cylinder pushrod must be
    adjusted so that there is about 1/16"
    clearance between the pushrod and master cylinder piston bore bottom and about 3/8"
    "free travel" at the pedal before the pushrod
    contacts the piston.
    For these brakes to work correctly and to
    their full capacity, the shoe linings must
    be ground to fit the drums so that full
    contact can occur; if this is not done, the
    linings will either contact only at both
    ends (lining arc too large) or only at the
    centers (lining arc too small); if this is
    not done, you are going to be unhappy.
    Before installing the shoes, set the upper
    adjustments so the shoes can be as far
    inward (away from the drums) as possible.
    ***emble the shoes and lower anchors (eccentrics) so the flats are horizontal and the dots are opposite each other, as close to each other as they can be. The purpose of these lower anchors is to allow centering the shoe linings in the drum.
    When all is ***embled, install the drums and
    turn the upper (11/16" hex heads) DOWNWARD
    until the shoes just contact the drums.
    If the system has been opened during brake
    overhaul, bleed the air out until there is a
    rock-hard pedal with no sponginess.
    Have a helper put about 30lbs of foot
    pressure on the pedal and hold it there.
    Loosen the lower anchor locknuts so that the
    anchor studs can be rotated by using a small
    wrench on the flats.
    Perform the lower anchor adjustent to cause
    the linings to be centered in the drums so
    that full lining contact can occur. Rotate the flats in each direction so that you can "feel" when the linings are contacting the drum at each end of the lining. Set the shoe/lining at the midpoint and hold the flat/stud from turning while tightening the locknut. Do this to both shoes at each brake, then have the helper release the foot pressure. Then reset the upper/clearance adjustment until the lining just contacts the drum surface without heavy drag.
    Repeat the above on all 4 brakes.
    Road test the vehicle to see if it now stops
    good and straight; readjust the clearance as
    necessary to cause it to do so. If it does
    not, there is unequal shoe contact somewhere
    that is causing one brake to stop more than
    another; like the shoes not properly fit to
    the drums, grease or oil or fluid on the
    linings etc.
    Failed to mention that the LONGER lining goes
    forward and the SHORTER lining goes rearward
    at each brake AND the larger wheel cylinder
    pistons face forward at each brake, and the
    larger wheel cylinders go on the front brakes
    and the smaller wheel cylinders go on the
    rear brakes, and all wheel cylinder ports
    angle towards the REAR of the vehicle, and
    bleeder screws must all be at the TOP...
  14. 40Tudor
    40Tudor
    from MN
    Beating a dead horse now, but what the heck - HELLMET got his answer and it's kind of a funny story.
    I put some F-100 drums up front on my '40 Ford last year. The complete ***embled brakes came from a friend's running, driving '39 Ford. I used the backing plate ***emblies to figure out the spindle clearance but one side required a ton more clearance than the other.
    Turns out I had two left side brakes and they were both put together the same way (long shoe on the right - not towards the back). He said it always pulled when braking. No wonder he was happy to give them away.:rolleyes::D
