Shaved Handles...what did You Do?
Discussion in 'The Hokey Ass Message Board' started by SquigMachine, Jan 30, 2009.
  1. SquigMachine
    SquigMachine
    i have pondered this alot and all i can come up with is electric or VERY cheap like a wire hanging out a cab corner that you pull(so im not the brightest)
    And its finally come down to this....I need a way to open the doors from the outside! and havent got a clue what to do So i decided to ask all of YOU what you did:cool: what would they have done in say the 60's or 50's and dont say not shave them because they came that way.
    i miss door handles
  2. krackerjack88
    krackerjack88
    from Fresno,Ca
    I have a wire hanger at the bottom of my door. Almost invisible.
  3. Crease
    Crease
    Great question.
    My buddy used a solenoid and a reed switch. The switch was hidden under the trim and he had a magnet on his key chain. It was really slick.
    I am hoping to do something a bit simpler, so Im looking forward to the responses.
  4. First off what kind and year of car is it? The way I did my cars years ago if they had vent windows was to simply take the vent lock off the vent window and push the vent open when I wanted to get in and reach in and use the inside door handle to open the door. There are all kinds of door solenoid kits available to open them by using a hidden switch. My old truck was done the old way that I mentioned earlier.
    Later,
  5. fab32
    fab32
    Another old way was a switch mounted right under to rocker panel. You just placed your toe under the rocker and lifted it activating the switch.
    Frank
  6. Dreddybear
    Dreddybear
    Yeah man. Electric solenoid. Hide the switch under the running board.
    The reed switch Idea is awesome.
  7. DIRTYBIRD
    DIRTYBIRD
    Solenoids, pull wires, bicycle brake cable whatever you want to use or spend on to open the doors it's up to you. You should learn about your particular latches...they best way is by removing them and exploring how they work. Find the part that makes the door open and hook something up. Disable the mechanism that locks them. Switch to aftermarket (bearclaw latches) If you have the ability and money. they operate with almost no effort so any old cheap solenoid will pop them. some original latches need alot of force to operate and some won't even work with solenoids at all. Solenoids with a remote control to open them is the best.
  8. SLAMED 59
    SLAMED 59
    ive used power locks out of 80s caddys they work ok but summit sells a kit for about 100.00 that works better and has every thing you need to do it
  9. chaddilac
    chaddilac
    I had a buddy that used those chrome smoothy door lock knobs that are on all the ford cars from the 90s, he mounted it up near the very corner of the window, just barely poking out of the top of the door, and uses it just like a regular door handle. I picked some up at the salvage and am going to use them on my 59 olds, and lose the solenoids!
  10. chaddilac
    chaddilac
    Also if you are going to use solenoids, you have to replace the rod from the inside door handle to the mechanism with braided wire. It's just too hard for the solenoid to push the mechanism and the spring on the inner door handle at the same time.
  11. lanny haas
    lanny haas
    from Phoenix AZ
    here is the kit I have cost around 100 bucks. Just pudh ****on on your key chain
  12. truckedup 28
    truckedup 28
    ive used trunk popers out of newer cars got them in the junk yards for lil of nothing. then wired them up to a hidden switch
  13. Dreddybear
    Dreddybear
    The more I think about it that reed switch idea is freaking rad. I am definitely stealing that when I build a custom.
  14. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    choke cable in the fenderwell
  15. Shifty Shifterton
    Shifty Shifterton
    Select a cool looking smooth door handle from another car/truck and put it on.
    2 birds, one stone. Cool & unique modification, and doesn't lock you out.
    As outlined above, remote poppers and safety pulls take time to install. Putting a different door handle on has got to be a similar level of work if the handle is chosen right.
    good luck
  16. tooslow54
    tooslow54
    I've got a solenoid hooked up, plus a manual cable that goes into the engine compartment. You would have to know where it was to locate it...
    The solenoid is currently only wired to a switch in the trunk (Kept the key latch for that) but I am planning on adding a remote to it.
  17. Tony Ray
    Tony Ray
    what would you guys recommend for my 50 shoebox? I'm in the same boat, P.O. shaved door and trunk. I want something I can use so I can have the doors and vent window locked. Not familer with the bearclaw latches..and wouldnt know a good popper kit from a bad one..
  18. Traditional with vitage parts, 1957-6x? caddy trunk solenoids,
    some light duty switch like from a glove box mounted in the door jamb that you use your comb to activate. and or a key operated swich in the fender well
    a safety cable inside the front fenders or rears if suicide
    If your hood is going to have an inside lock, make sure you put remote jumpers some place if you forgo the cables.
    that reed switch and magnet is pretty cool, had one of those for a kill switch on a 80's buick.
    the remotes are nice
  19. metalman
    metalman
    My experance has been with electric solenoid you must put a remote cable somewhere as the solenoid will fail sooner or later. sometime both at they same time.
    My car has dissabled vents, but then I rairly roll the windows up, very little rain here.
    I had a buddy have his door open at speed when the rock he ran over hit the switch under the rocker. Might want to shield it with something if you go that route.
    My favorite was a guy that had a slot cut just below his beltline molding in his door. To open it he would bring out a card (like a motel room key), slide it in and his door would open. Wow, trick to have a card reader I thought, later I found out it was just a micro switch the card would push, any credit card would open it.
  20. FCCOOL
    FCCOOL
    in australia, you have to have a mechanical visible way to open the door so in a accident were you may loose the battery emergency services can still get in, i have flush small round push ****ons that i made with the same contour as the door.
    the reed switch sound easy to steal, i would hook up some other reed switches nearby to a alarm so unless you get it on the right spot the alarm is activated, that way if a theif spots you with your magnet and tries the same he will have to know exactly were to put the magnet and not just feel around with a magnet till he finds the switch.
  21. born loser
    born loser
    from dallas
    I cut the latch off the door and welded onto the body. Took the 'pin' off the body and put on the door. Then the stock handle off the inside and mounted it in the cab corners. A quick 'elbow jab' to hit the handle pops them open from the inside. Outside I have slightly domed push****ons on the back of the cab. They are baaaaaaaaaarely noticeable. '61 Apache.
  22. I'd like to see pics of that.
    I have a spal kit and it is junk.
    I have had both doors fail at the same time. (not the remote and not the battery)
    Wish I had never shaved the doors and this is on the OTM.
    They sure look cool, but you don't, when your stuck outside. :|
  23. born loser
    born loser
    from dallas
    I'll run outside and take a few.
  24. DIRTYBIRD
    DIRTYBIRD
    That ****s man. I never finished the install for my thunderbird. was gonna hook up a safety cable. I found a viper alarm for 20 bux and got some hand me down mooneyes solenoids that are weak and cheap. They never failed though. I only got stuck out once when my ground had corrosion. I just broke my vent window drive pin by pushing it really hard(easy to replace) I have done a few other cars with various differnet methods and parts....never had problmes.
  25. kkoacolonel
    kkoacolonel
    from Union,NJ
    Why don't you do this.Very simple,shave the door handles,and if you have non-crank vent windows,pop the pin that holds the latch in.When you want to get in your car or truck,just swing the vent window open.
    This way,if your battery goes dead,you can still get into it.
  26. flatblackindustries
    flatblackindustries
    from Ogden, UT
    I admit it's a little ghetto, but this is exactly how my 54 210 is done. :)
  27. SquigMachine
    SquigMachine
    I like the push ****on under the rocker idea but me and electricity dont go well together...
    o' yea its on a 55' chevy pickup
  28. awe hell thats the easy part of this project of yours, if you can get the rest working this would be a piece of cake for you. dont rush and use the right stuff,
    http://www.ado13.com/techs/relay.htm
  29. The deal I did was on a 57 Chevy pick up and all I did was to take the vent lock off. Fail safe!
    Later,
  30. layin_frame_56
    layin_frame_56
    from Ohio
    I've used hood release cables mounted in the inner front fenders before and electric I prefer the hood releases very cheap way to go and i have found them to be more reliable. Just my $0.02
