Shaved Handles...what did You Do?
Discussion in 'The Hokey Ass Message Board' started by SquigMachine, Jan 30, 2009.
  1. SquigMachine
    SquigMachine
    i think the little ****on mixed with the vent window idea incase of ****on failure.....cant wait till i finish!:D
    Thanks All
  2. poorboy
    poorboy
    im just reaching in until i get my side gl***. then i'll probably run some kinda cable into the engine compartment or trunk. or at least until i get tired of it :)
  3. Chaoticcustoms
    Chaoticcustoms
    On my daily ive got an autoloc kit, which really isnt that expensive, lil over a hundred if i remember right, then on the p***enger side a stainless wire that runs to the inside of the bottom of the fender...for the oops, or **** my keyfob is inthere trick..then heres a cool trick to make the soleniods last longer, we went to walmart, got baby ******s for bottles and put them over the wire and top of the solenoid and walla....no more corrosion...
  4. Midnight 50
    Midnight 50
    Search "door popper" on ebay.
  5. I went the same way. As well as the trunk (hidden under the gas fill door)
  6. Dads-53
    Dads-53
    Just because your to damn tight to buy the real deal. Hope your amking the best of a bad winter. O I used starter selinoids.
    Don
  7. Hey Dad, I resemble that remark. M J has said for years that the only time I would take her and the girls out to the state fair was on free day. I always thought that I was just being thrifty.
    Besides that you probably had some one give you the solenoids.
    Later,
    ****:D
  8. davedeltadog
    davedeltadog
    Use the most simple way you can. I'm using remote electric windows controled by a Hotronics cpu. I just roll down the windows and reach inside. Never had a breakdown with it, but would never shave door handles again. Had shaved handles on my 56 Merc when I was a kid, had a dummy spot light that rotated and pulled a cable though the door hinge to release the latch. It's cheap and simple.
  9. metal man
    metal man
    I did that vent wing thing for 18 years, got over it and put door handles on it when I finally painted it .
