Molasses Source for Rust Removal
Discussion in 'The Hokey Ass Message Board' started by no bux rod, Jan 11, 2009.
  1. no bux rod
    no bux rod
    I have been trying to track down a source for bulk mol***es in North GA and have not found any. Anyone know of a real feed mill within 100 miles of Atlanta? Bulk is about $2/ gal. while the bottled stuff is $9.
    I am familiar with electrolysis rust removal but there are applications (parts) where the mol***es/ water solution gets into interior voids like water jackets. I am planning on setting up both.
    Thanks, N B R
  2. fiftyv8
    fiftyv8
    from CO & WA
    PM povertyflats who did a thread on this quite awhile back.
    Mol***es can be used for livestock, some larger shops have been know to stock smaller quanities, but I have been told mol***es is also used to form a base mixture for crop spraying so if you know of some local store that handles poisons and crop spray stuff you maybe able to source it thru them.
    It acts as a sticking agent and also a wetting agent in the sprays.
  3. It can be found at feed stores as noted.
    I understand that having sulfur in the mol***es is the way to go.
    Supermarket mol***es is sulfur free most times.
  4. no bux rod
    no bux rod
    BTTT Is anyone in North GA derusting with Mol***es?
  5. plym_46
    plym_46
    from central NY
    This any where near???
    <TABLE cellSpacing=3 cellPadding=4 width="95%" bgColor=#ffffff border=2><TBODY><TR><TD>Flint River Mills, Inc.</TD><TD>Bainbridge, GA. - Phone: 1-800-841-8502</TD></TR></TBODY></TABLE>
    Also check homebrewing supply places. Or make a blend of storebought mol***es and Vinegar instead of water.
    Check your area for restaurant supply houses commercial food service supply house, their commercial baking supply catalogs should have it by the gallon. If you can't get it through them ask at a bakery or the bakery dept of your local grocery store, perhaps the manager can order it by the gallon for you from their source.
  6. 343w
    343w
    We buy ours at : Coosa Valley Milling & Hardware, 30620 Hwy 25, Wilsonville,Al. Tel.# 205-669-6605. They can sell you large amounts,bring your own container, and I would call in advance to make sure they have the amt. you need and the price.
  7. no55mad
    no55mad
    Do you derust with 100% mol***es or does it get cut with water? Seems I remember a past post claiming the parts soaked for 30 days for it to work. Does it eat the metal away too like vinegar or is it less agressive? How is the part neutralized after the process? Thanks for any inputs!
  8. lostn51
    lostn51
    from Tennessee
    Just think I have been derusting my bisquits for the last 40 years!:D
  9. RichG
    RichG
  10. makgreens
    makgreens
    i think my buddies lumber yard has some usually
    ill check for ya
  11. no bux rod
    no bux rod
    Thanks guys, I track dowm either Wilsonville or Bainbridge locations.
    As for Mol***es derusting: The average mi ratio I have read is 6:1...water to Mol. The feed store Mol***es is supposed to be better since it has some sulfur in it. Soak for 1 -4 weeks bdepending on rust level. If you leave it in too long I think the metal picks up some hydrogen. I'll be learning onvce I can find the stuff.
    N B R
  12. 343w
    343w
    I've read that it eats br*** and aluminum as well as cast iron. Don't know for sure, I've used it for sheet metal with great result. Good luck!
  13. 56don
    56don
    I just bought some at Tractor Supply.I think they are everywhere in the Southeast.
  14. mx6262
    mx6262
    Try your local Farm or feed & seed store.
    I'm heading that way my self.:rolleyes:
