1966 Dodge motorhome engine removal?
Discussion in 'The Hokey Ass Message Board' started by Defarm, Feb 1, 2009.
  1. Defarm
    Defarm
    Hi All,
    I have a 1966 Dodge motorhome (Islander) with a 318 poly hemi V8, and torqueflight. I want to remove the engine; Does anyone know if this comes out the front or what is the best way to get it out? Thanks!:eek:
  2. Probably goes out the front. I've seen Dodge vans get the engine taken out the p***enger door.
    If you are trying to save the motorhome, then don't take a sawzall to the front of it. If you don't care about it, hack away.
  3. coupster
    coupster
    from Oscoda Mi
    If you ain't gonna save the motorhome, axe=access hole.
  4. 318 poly hemi huh
  5. junkyardroad
    junkyardroad
    from Colorado
    How about a poly hemi acetylene torch?
  6. Defarm
    Defarm
    Yepper, it's a poly hemi that I want to put in a rod, welding the frame now; don't give a rat's *** about the motorhome itself!
  7. Little Wing
    Little Wing
    from Northeast
    Most of those had a removable rad support section,,otherwise out the p***. side door. ( take the door off of course )
  8. stude_trucks
    stude_trucks
    Dude, no 318's were hemis. If you are thinking you can make that a hemi, you might want to check that before you go through all the effort. 318's aren't that hard or expensive to come by. Might be easier to get one without a motorhome attached to it.
  9. Defarm
    Defarm
    stude trucks, "Dude": I've been playing with street rods since 1966; Chrysler made a factory 318 poly hemi. Buy a book & look it up, this is not the 318 small block that you may be thinking of. I understand the confusion though.
  10. stude_trucks
    stude_trucks
    Well, cool, but check your facts again. First off, a poly isn't even a hemi. Is not a hemi until the hemi heads go on and they never made a 318 hemi. Now please go check that fact. Or just do what you want to do, and then find out the hard way later.
    You see a 318 hemi on this list? http://www.hothemiheads.com/hemi_info/hemi_engine_id.html
    Maybe you know more about hemis than these guys? Now maybe it might be possible to fit some hemi heads on a 318 block, I have no idea, but why in the hell would you want to try to do that? Just go get a 331 hemi if you want one that bad. they are pretty easy to get and relatively cheap.
  11. patrick66
    patrick66
    No 318 Hemis were ever made, period. Only the A-block Poly engines and the LA-block Wedge-design engines. No Hemis. Ever.
  12. hotrod-Linkin
    hotrod-Linkin
    no dudes,he's been messing with them for years.he has to be right....
    bwaahaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
  13. 41 C28
    41 C28
  14. hotrod-Linkin
    hotrod-Linkin
    dynomite....oh then you might hurt the poly-hemi
  15. Pir8Darryl
    Pir8Darryl
    318 poly-hemi.... Now that there's funny, I dont care who 'ya are :D
  16. povertyflats
    povertyflats
    from Missouri
    I don't like the way he called my pal stude trucks "Dude". Bad at***ude. I'm gonna go make some popcorn.
  17. Jimv
    Jimv
    Is a "motorhome" traditional????Or have anything to do with this board??WTF!!
    JimV
  18. hotrod-Linkin
    hotrod-Linkin
    well it's a hemi..so he says it's traditional.
  19. seriously dudes, the hi-po 318 poly hemi big block is super rare. it only came in the equally rare landspeed motorhomes that were only sold in washington (not dc). git yer fax strate
  20. R Pope
    R Pope
    C'mon, guys, be nice. Somebody's been feeding this guy a load of ****, it ain't his fault he can't taste it.
  21. 31modelo
    31modelo
    Playin with rods since 66 and can't figure how to get an engine out, weird.
  22. hotrod-Linkin
    hotrod-Linkin
    but you can buy a book and look it up..what book..antique roadshow for mopars ????
  23. Defarm
    Defarm
    The 318 poly hemi is a semi-hemispherical combustion chamber; that is why they are called a poly hemi versus a 318 small block. So then, if I'm full of ****, then y'all might want to tell that to these other guys on H.A.M.B., who are discussing the 318 hemi on another board here, Early Dodge Poly/Hemi Questions, http://www.jalopyjournal.com/forum/showthread.php?t=318415.
  24. did you read that thread?
  25. Juztyn00
    Juztyn00
    I think you mean a 318 polyspherical. Which would be correct.. Saying it's a poly hemi doesn't make sense. Its either one or the other and to my understanding, they didn't make a hemi 318
  26. This is the first time I have ever heard a poly called a hemi. It's either a hemi or it's not, period. Semi hemi isn't a hemi. If the inside of the head is not half a sphere, it is not a hemi. Call it what you choose, but don't expect the rest of the world to agree with you. The thread that you linked says "poly/hemi". The "slash" indicates hemi and/or poly. Nowhere in the thread does anyone say a poly is a hemi, nor do they say that there was ever a 318 hemi. Only you know if you are FOS, but I will ***ume you are misinformed and, perhaps, lack some reading comprehension.
  27. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Thats funny right there..no matter who you are..
  28. Well, before you destroy the motorhome, be aware there's a decent vintage camper market out there, a lot of that stuff is damned near impossible to find, so it might be worth the trouble to take it apart the right way and ebay the extra pieces.
  29. hotrod-Linkin
    hotrod-Linkin
    i'm still looking for the book he wants us to buy.
  30. i'm still looking for the book he wants us to buy.
    I read a book once. I never found Waldo
