cad lasalle behind a flathead??
Discussion in 'The Hokey Ass Message Board' started by Russ Gaylord Fontana, Feb 3, 2009.
  1. Russ Gaylord Fontana
    from Home
    Just wondering if anyone has any experience of cad lasalle transmissions, I'm considering swapping one into my sprint car instead of the Ford '39 box. I've been told that there tougher and have a quicker shift. It's already been converted to torque tube and has a flathead bellhousing adaptor, but any ideas on this would be appreciated.
    <!-- / message -->
  2. R Pope
    R Pope
    That used to be the hot setup, when there was nothing better available. Lots of better choices out there now, but if you have one and it doesn't need any hard-to-find repairs, it will work. If you bust it the parts might be hard to find.
  3. Dale Fairfax
    Dale Fairfax
    Since it's already set up for a torque tube and ready to bolt to your Flathead, what's the question? It's much stouter than the the Ford box and it's highly unlikely that you'll ever break it. You say you want to put it in a sprint car-I have to ***ume it's for vintage racing or the street. In neither case do I see any risk. All the other proposed solutions don't recognize what you're trying to accomplish: like keeping the torque tube.
    303racer likes this.
  4. Russ Gaylord Fontana
    from Home
    Thanks Dale, It's for vintage racing, appreciate the help!!
  5. Sounds bad ***, may we see?
  6. Russ Gaylord Fontana
    from Home
  7. 38FLATTIE
    38FLATTIE
    from Colorado
    Cool car. I've got a ****** if you need one.
  8. alchemy
    alchemy
    Even though you have the correct bellhousing, and the back has been converted to a torquetube, it's probably not a "bolt-in". The Lasalle ******s were longer. I think that whole ***embly is about 2 inches longer than an old Ford trans. Get out the tape measure before you commit, cause you may need to move your crossmember and shorten the TT.
  9. as far as strength is concerned, a 37-39 Lasalle is more then enuff....i have one behind a very stout early model oldsmobile in a 2700 pound car and ive done about everything you can to blow it..it still keeps on gettin it. Alchemy is right check the tailshaft length because they do vary...good luck...
    T. Hilton
  10. Dirtynails
    Dirtynails
    from garage
    if the trans is adapted go for it, a car that has that " look" needs to use vintage parts!.
    You in the UK? going to do Shelsey etc? If so i look forward to seeing pics of it in action.
    James Corbett,An Artist from Australia who is having an exhibiton in London at the moment built this and races it very successfullty down here. The rules are pretty strict,no later components from beyond the cars era.
