Help with my 351W ignition
Discussion in 'The Hokey Ass Message Board' started by C130Driver, Feb 3, 2009.
  1. C130Driver
    C130Driver
    Help! Noob here! I just bought a 351W out of a 84 Ford F150 (I'm told). Someone did a real hack job when they removed it and now I can't figure out what wires go where. First, it's got the magnetic pickup in the distributor. How in the world does that hook up? Thanks
  2. 26TA&PFCC
    26TA&PFCC
    from Tucson
    It hooks to the ignition control box mounted on the rh inner fender wall of that truck. If you don't have an engine harness, you might be replacing this with after market stuff.
    Also note that 351 W have a unique firing order, unless somebody threw in a 302 cam, then you need that firing order.
  3. if you don't have the Ford ignition control box , you can use a MSD box to make it work. the wiring instructions comes with it
  4. carkiller
    carkiller
    Go to your local parts store order a distri****er for a 69 mustang 351 W, Set ya back about $50.00 comes w/new points and condener.
  5. hotroddon
    hotroddon
    Well, an 84 Pickup should have a Duraspark ignition, which means you need the Duraspark box. There should be 3 wires coming out of the Dist, purple, black, and orange that go to the box. It also uses a special TFI coil.
  6. chevyshack
    chevyshack
    Disnt the winsor and 302 share the same firing order some years? Used to have a 5.0 mustang that my uncle swaped the wires around to 351 windsor firing order and than argued that it was a windsor. Cant tell him anything.
  7. hotroddon
    hotroddon
    The ford 302 (5.0) went to the 351W (Windsor) firing order in 1985 on the roller cam HO motors.
  8. beatnik
    beatnik
    Duraspark Wiring
  9. MercManMario
    MercManMario
    I had awful luck with the duraspark boxes ****ting the bed. They don't like the heat or wet. Go get yourself a nice MSD 6A for $25 bucks at the next swap meet ;)
  10. Jalopy Joker
    Jalopy Joker
    What is the firing order for a 351 W ? All years the same? Also, anyone have the wiring diagram for the MSD 6A for use with the Windsor?
    Thanks
  11. I replaced the duraspark box with a HEI 4 pin module that I mounted under the dash. The dizzy looks factory.
  12. 59ratgasser
    59ratgasser
    from BFE,kansas
    Go with a pertronix its simple and clean and a good hot spark. check your local parts house.
  13. C130Driver
    C130Driver
    Wow! Thanks alot especially for the immediate responses. Wow!! I guess I am going to go with an aftermarket ignition module, probably the MSD 6AL. So should I go ahead and get a new distributor?
  14. AnimalAin
    AnimalAin
    The Duraspark distributer will work fine. Better than points.
  15. C130Driver
    C130Driver
    so here's the deal, Autozone sels the ford/duralast module for $37 and a new mag pickup for $18. I can get a new points distributor for $45. Which way should I go? Thanks
  16. MercManMario
    MercManMario
    Do yourself a favor and DON'T go back to points. Thats like going from XBOX to Caleco Vision. Keep the stock dizzy and run an MSD. The 6A is cheaper than the 6AL. Only difference is the 6AL has a rev limiter. 6A's might even be available at the 'Zone, as i know they stock some MSD. I've had an MSD in my race car for 5 years, and in my friends mustang for almost 10. Simple wiring, and great detailed instruction. Good Luck!
  17. hotroddon
    hotroddon
  18. Bluedscrewed&tattooed
    from AUSTIN,TX
    351 firing order 1-3-7-2-6-5-4-8
    302 firing order 1-5-4-2-6-3-7-8
    dont put point back in!
  19. Beef Stew
    Beef Stew
    from So Cal
  20. hotroddon
    hotroddon
    as stated before, late 302's (85 and newer roller cam HO) used the 351 firing order.
  21. C130Driver
    C130Driver
