54 dash in a 30/31 Not sure yet.. Thoughts ?
Discussion in 'The Hokey Ass Message Board' started by Chopperman, Feb 3, 2009.
  1. Chopperman
    Chopperman
    So I picked this 54 ford dash up for my A... After cutting, whacking, and t*******, this is where I'm at..This thing is still pretty big inside the car.. I think i need to lower the top and cut out some of the original A dash rail because it's sticking up past the PS and DS door line a bit. No a great side profile if you know what I mean.
    I have all the original knobs, engine turned stuff and glove box..
    It's still going to take a TON of work to get it all to look and fit right. I also mocked the speedo up in the center just to see how it looked.. I'm kinda 50 50 on it..
    I know, I know... It's your ride do what you want, but I also like a little feedback..
    What are your thoughts on the overall look of the dash and the centered speedo ?
    Thanks
  2. chopperjeff
    chopperjeff
    from minnesota
  3. lockwoodkustoms
    lockwoodkustoms
    I like it!!!!!!!!!!!
  4. 29Jay
    29Jay
    from Ft Worth
    I'm digg'n the speedo in the center. Agree w/ ya on t******* it a little closer to the stock dash. I think you need to get it closer before you lower your approvial rating. I'm guessing as you work it a little more, you will like it more. I say, keep going!
    Jay
  5. HOTRODPRIMER
    HOTRODPRIMER
    I'm liking it,,but the speedometer needs to be in the correct position. HRP
  6. Chopperman
    Chopperman
    Like I said.. I'm 50 50... Same amount of work either way..
    Center mounted means more room for speedo guts but i need to fab a plate for old location
    original location means i need to make room for guts....
  7. mecutem
    mecutem
    I like what you are doing. I like a centered speedo too. I think all the do-dads that go around the speedo need to be center with the speedo to have it look balanced. Steve
  8. HotRod33
    HotRod33
    I think the dash will be killer...I like the speedo centered up.....
  9. 66Newport
    66Newport
    I like the **** out of it! Looks great with the Speedo centered, but like Mecutum said, think about centering some other things around it for a good balance. I say keep it, I thinks it looks great!
  10. ChevyGirlRox
    ChevyGirlRox
    from Ohio
    I think this is a 50/51 Ford dash in a coupe but you get the idea. It can be done and it can look good! And FWIW I like your speedo in the center : D
    In this car (from the Dayton area, friend of S****s, not sure if owner is on HAMB or not...)
  11. Bob37
    Bob37
    Nice dash. Should look great in either location of speedometer.
  12. Harris
    Harris
    1st - love the look of that dash, including the centered speedo.
    2nd - I can sympathize with your feelings about it being too big, not trying to jack your thread, but here's where I'm at cramming an early 50's desoto dash into my A. I just keep telling myself to ignore my current concerns and concentrate on my original vision for the dash - it helps a little...
  13. milorat
    milorat
    If you cut your dash to fit with the original dash rail,it makes and easier installation. Here is an example.I think your dash would look good this way.For me,I like the speedo in its original position.
  14. ChevyGirlRox
    ChevyGirlRox
    from Ohio
    Hey, you are on here! Look up a couple posts, I just posted pics of your dash in your car! :D
  15. moon man
    moon man
    dash looks good. little more t*******. keep it up.....
  16. Chopperman
    Chopperman
    trimmed it up a bit....
    Not sure if i will have room for speedo now, buw we will see
  17. Chopperman
    Chopperman
    this will be a weld in dash
  18. choppintops
    choppintops
    Looks good, I like it.
  19. Love it! Doing something like it on my car, so think about that the cluster isn't Symmetric! It fooled me in the begining, 'cause I always thought it was! - Keep up the good work
    Klaus
  20. robt500
    robt500
    from Lex, KY
    The gauges were in the middle until '33 so... I think the speedo in the middle is cool for your A. The later dash looks neat in there. Moving the speedo to the middle blends it into the older car a little. either way
  21. Chopperman
    Chopperman
    Couple updates..
    I've been t******* away.. Still up in the air on the speedo.. I'me going to fill it all in without it, then maybe hit the junk yard and look for another centered up speedo ( just a bit smaller )
    I'm liking the overall look of this dash though.. It's different for sho
    EDIT : I'm going to pick up a piece of engine turned stock for the middle nd center up some vintage SW guages
  22. tltony
    tltony
    from El Cajon
    Here's a 51 Crown Victoria dash in a 28 RPU. I had to section it in three place to get the proportions right. The perforated ares is stainless steel filter medium from Mc Master Carr that I cut and dimple-die'd to fit.
    Tony
  23. Chopperman
    Chopperman
    so i decided to morph the orginal A speedo into the 54 dash.. I like it
    I had to reverse the stock speedo which was fun
  24. Oh Hell Yeah!! Liking the new design!!!
    That looks killer with the original speedo centered on the dash....Thumbs up!!!
  25. Chopperman
    Chopperman
    Thanks... it was a total spur of the moment thing. Originaly i thought it would look too small. but it looks just right
  26. Mike Paul
    Mike Paul
    Heres mine '53 if I remember right
  27. crapshoot
    crapshoot
    it looks a keeper, the last minute model A speedo did the trick man
  28. Chopperman
    Chopperman
    Looking better:D
    Gonna have break out the bondo though:eek:
    My wife said it looked SCARY
  29. marx
    marx
    Dammit, that's so cool!!!! Great job!
  30. HOTRODPRIMER
    HOTRODPRIMER
    I modified the 54 dash for the wagon and it too will benifit from the use of a piece of engine turned metal ( where the piece of white poster board is in the photo)placed inside of the original aluminum piece.HRP
