can i get wide whitewalls?
Discussion in 'The Hokey Ass Message Board' started by blownplymouthrat, Feb 4, 2009.
  1. blownplymouthrat
    blownplymouthrat
    from florida
    i need some whitewall tires in a 295 50 15 or equivalent. ive looked at coker but i dont see anything that big.
  2. Kustom7777
    Kustom7777
    from Austin, TX
    try lucas
    dont have the address or phone,,,,but im sure someone here will
  3. monsterflake
    monsterflake
    diamondback might make some, but i'm not sure that it's a good idea...that's not a tire that should be a wide white.
  4. 41hemi
    41hemi
  5. How will you get a WIDE whitewall on a low profile tire? Just wonderin.
  6. blownplymouthrat
    blownplymouthrat
    from florida
    the tire does not need to be low profile. 50 series . just something in the realm of 28 to 30 inch tall 12 inch section width.
    thanks.
  7. monsterflake
    monsterflake
    a 50 series will not be very tall. what's this going on? wait a minnit...is this a rat rod?
  8. pan-dragger
    pan-dragger
    i was thinkin the same thing.
  9. lostn51
    lostn51
    from Tennessee
    I wonder how long this thread will be going for?
  10. RichG
    RichG
    Antennas are twinging....uh oh, looks like the popcorn wagon is on its way...
  11. bubba69
    bubba69
    Try the White wall candy store. They can get all sizes. They have their tires made. They've had problems in the past but they are under new ownership, good people.
  12. skunx1964
    skunx1964
    295---width
    50---height
    15---rim size
    a 50 series tire is low profile, and pretty wide, prolly 8 to 9 inches wide
  13. 60srailjob
    60srailjob
    from nowhere
    Try Diamondback tire or The Candy Store, But I'm not getting the WW 50 series, I guess I dont get it because I DONT run radial tires.................
  14. t-town-track-t
    t-town-track-t
    from Tulsa
    actually, the first number is the width, and while you are partially correct about the second number being the height, most people are confused about how it signifies it.
    The second number is a percentage. In other words that wire would have a side wall that was 50% the width of the tread. SO a 50 series tire on a 185 is going to have a shorter sidewall than a 50 series on a 305. Does that make sense?
    so if you figured that the tread was 8-9 inches than its safe to say that the sidewall will end up 4-4.5 inches, which will leave him plenty of room for a 3" white wall!
  15. 60srailjob
    60srailjob
    from nowhere
    Hey t-town-track-t good explanation on the tires...........
  16. AnimalAin
    AnimalAin
    That tire should be almost 12 inches wide (section width), with a tread around 9-10 inches, and about 27 inches tall.
  17. BigBlockMopar
    BigBlockMopar
    10 inch = 254mm
    11.6 inch = 295mm. A 50-series tire makes 5.8 inch tire height.
    Here's a 275/60 tire to get an idea...
    Here's a 325/50...
  18. skunx1964
    skunx1964
    ya, i just didnt want to try to explain it like you did, it wouldnt have come out as understandible, lol. thanx. im just sick of hearin guys who say they want a 50 or 60 series tire so itll be wider...... clueless
