how do you get a 50 merc back glass in after its been chopped?
Discussion in 'The Hokey Ass Message Board' started by 51Hg, Feb 5, 2009.
  1. 51Hg
    51Hg
    Everyone knows that I have gl***guys 51 merc. It has a 50 merc back gl*** in it. (which had plexi installed when I bought it). The plexi is yellow and scrached and hard to see through.
    When I purchased the car it came with an original 50 merc back gl***. So now I decided it was time to put the original in. I had a local gl*** guy come over that said he has put gl*** in old cars before and tried to install the original back gl***. no luck. he swears that the orginal back gl*** will not fit.
    Note: yes the top has been chopped. (just in case you didn't pay attention to the ***le)
    What is wrong? Are there certain tricks or black magic? are 50 windows really that much of a pain in the *** to install?
    I talked to gl***guy and he said it would go in, and that this gl*** has been in the car before.
    Anyone installed one before?
    Anyone near Memphis, TN. thats done it before and that could help?
    Know of some place near memphis I could take it to?:confused:
  2. dirt
    dirt
    it sounds su****ious to me. if the gl*** was in it before why replace it with plexi? i would ***ume the window opening got changed when the chop was done. if you cant get the gl*** to fit you can always cut another piece of plexi until you figure out the problem.
  3. Eyeball
    Eyeball
    I talked to Gl***guy allot when I was chopping mine and he told me he had the original back gl*** in it but it looked like a bubble and preferred the look of the plexi as it laid nice and flat. The chop on mine is very similar to yours and I know I will have to make the same decision when the time comes. I think you may want to get another installer to take a look at it. I miss that car you need to post up some pics of it more often.​
  4. slddnmatt
    slddnmatt
    they are actually pretty easy to install. i would say the opening has been altered or its tweeked from the chop and the gl*** doesnt fit so he went for the plexy. post up some pics of the window opening.
  5. Gigantor
    Gigantor
    Wont the old shoelace trick do the job? I ***ume you laid the gl*** along the back and measured every which way to confirmt that it actually will fit, right? I'd image a 2-man job to do it, but if it's the right gl***, it can be done.
  6. roddinron
    roddinron
    And if you do reinstall plastic, wouldn't lexan be a better choice? Plexi doesn't last long.
  7. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    It was lexan, and due to what eyeball said. Flattened out look more, that thing is chopped hefty, the stock gl*** might look wierd.
    Only thing I can say is try some dishsoap, that makes it easier... installing that gl*** is a pain in the ****. Sometimes it goes right in, sometimes tells you where to go for an hour or so.
  8. the re-pop back gl*** is laminated and can be trimmed if needed. it also comes in clear or green and grey tinted. if you can't find them local. check my website the chopped 4 door merc got a smoked grey one
    Jim
  9. brewsir
    brewsir
    Someone on here (wasn't it you noname?) Showed a post on how to cut down a windshield to make a custom back gl***...may have to do that if you want gl*** with a nice profile!
  10. atomickustom
    atomickustom
    The guy who looked at your car is a wussy!
    The gl*** should drop right in. You need two people, one to position it from the outside and push when the time comes and one on the inside to pull the cord out of the rubber and do a little convincing of the rubber here and there. At least one of the two people has to be experienced or the gl*** might get broken.
    The lay-down will make the inside guy's job much harder, but that doesn't mean it can't be done. Find another gl*** shop that does automotive gl***. Ask around. Someone will do it.
  11. flamedabone
    flamedabone
    My darling bride and I did mine and it ****ED. She is just a bit over 100lbs and just doesn't have the heft.
    I did mine from the outside pulling into the inside. Start from teh bottom with lots of dish soap and about a 3/16 or 1/4 rope. After it was in there, I still had to go around the gasket with a pair of pliers and **** teh window all the way in place.
    It took an entire saturday afternoon...
    By the way, it is no secret that I LOVE your car. It was one of three Mercs I had in my minds eye when I built mine.
    Good luck, -Abone.
  12. SlowandLow63
    SlowandLow63
    from Central NJ
    This is most certainly not chopper error. Dave has chopped many a car and they are perfect. So put that out of your minds.
    The Merc in question is so radically chopped (as Mercs go) that it may be a bit different. Traditional thinking may not apply here, you might need to be as outside the box as Dave usually is.
    BTW, one of my favorite Mercs as well. Especially when Van Hagar is blasting from the speakers. ;)
    My other fav was built by the guy who posted just above me...
  13. If your still in doubt about the actual fit, Lay the Gl*** in without the Gasket and check that it lays in contact all the way around the opening. You should also have 1/4" to 3/8" gap for the rubber around the edge. If it all checks out right the Gl*** will go in. It's also a good way to see if you like the profile of the Gl*** prior to actually installing it.
    The Wizzard
  14. 51Hg
    51Hg
    If you lay the gl*** in the channel without the seal it touches on both sides where it is rounded and the original gl*** would have to be trimmed about 1/4" on both sides.
    Now on the top and bottom the gl*** is too short about 1/2".
    If I lay the plexi that was in the car when I bought it, on the original gl*** it is bigger by about the same on the top and bottom, and short by about the same where it is rounded on the sides.
    So i don't think the original gl*** is going to fit.
    What are my options?
    lexan is a cheeper temp fix but i will have to replace about every 2 to 3 years.
    How much would it cost to have custom gl*** made?
    Anyone know a custom gl*** shop near memphis?
  15. 51Hg
    51Hg
    now I'm not knocking dave's craftsmanship, cause the car is killer. just confused because he says it should fit. so is the gl*** guy that was here today a wuss or is the original gl*** a no fit?
  16. pasadenahotrod
    pasadenahotrod
    from Texas
    The old rule of chopped tops in the hot rod world was "If it is done right the gl*** fits, sure you may have to cut 6 windshields to get one that doesn't crack while cutting but, it fits."
    The rule is this, a simple one, "If the gl*** is plastic the chop isn't right." No excuses, no whining, the steel wasn't cut or handled right and now you're in deep ****ola, and the easy way out is plastic, not the right way, the easy way.
    I felt a rise in the BS tide, and a disturbance in the Force, when you said the cutter said "the stock gl*** just didn't look right and the plastic gave it just the right look".
    Yeah right. An ego is a terrible thing to bruise.
    In those Mercs where the back gl*** is just laid down rather than cut down the ONLY reason the stock gl*** won't fit is because the window opening was not properly braced before cutting it loose...oops!
  17. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Try reinstalling it with someone who isnt afraid of giving it the ol Polish gl*** installer hand, smacking it around to get it in. Scary at first haha.
    That is untrue above about the gap, the rubber is staggered so there is no perfect gap around it, look into the rubber you will see what I mean. It isnt like installing a V **** windshileld.
  18. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Or...people on here know the car and builder and know why there was lexan in there.
    Easy there Matlock...
  19. sick50ford
    sick50ford
    from nor cal
    if the gl*** is abit oversized, trim it down with a grinder, i shaved some gl*** with a 4" grinder and some 80 grit, no prob.
    if its undersized, your f*cked
    when i had the gl*** made for the ford <------ i watched the gl*** guy finish up and he was thowning the gl*** at a 60 grit belt sander, when i got home it still needed a little m***age.
  20. brewsir
    brewsir
    Yea...try that with tempered gl*** and let us know how long it took to clean up all the little pieces.
  21. sick50ford
    sick50ford
    from nor cal
    i was thinking that but forgot to mention. gl*** type, check.
  22. FEDER
    FEDER
    When OLD BEET installed the back gl*** in My Sons chopped Merc it looked WAY OFF at first. The gl*** had been in the hot attick laying face down all summer. It opened up damn near 3/4 of an inch. BEET layed it in the hole and let it set a while the MUSCLED it in with great finess and success. It fit perfect. Maybe You have the same problem.
    FEDER
  23. the 50 fourdoor went all dark gl***. it was the first laminated one I'd installed and he wanted to delete the chrome trim. I used two "wbl 685" gaskets, from 67-72 chevrolet pickups. I cut them and made two splices in the center top and bottom. they filled the gap nicely and had room to move around a bit. after it was in. I pushed the gasket tight to the body and sealed between the gasket and the gl*** with Ureathane and it's set for life.
    i think this might work for you......Jim
  24. SlowandLow63
    SlowandLow63
    from Central NJ
    Lol.
    He's got it all figured out from halfway across the country. Ya know seeing the car, knowing the builder, knowing all the other cars he's built, knowing that he owns an AUTO GL*** SHOP.
    If Dave says there was gl*** in it, he can put gl*** in it.
