FNG, has a question. I am building a a 47 Plymouth Sedan, stock on the outside retro under the skin. Flathead, bored, cam, ported, decked and blocked, dual carb and exhaust. Here is what I have done so far, 1. Stripped to bare metal sanded and cleaned. Sealed it with Nason 491-17 etching primers, lightly blocked it with 180 dry, Three wet coats of Nason 421-19 2K Ure Primer, guide coat, blocke 180 to 220, reshot it with three more coats, guide coat sanded with 320 to 400. I have all of the pieces to 400 ( took the doors, fenders, hood and trunk lid off) Now should i spray a light coat of primer then sand with 500-600 or can I just keep sanding with 500-600 making sure I do not cut to metal? Also, should I sand it wet or dry?
Depends on the paint you are using. Oldder style enamels, and single stage, you can realistically cut with 320-400 and then shoot. Lacquers were 400, modern base clear, Dupont usually I cut with 400 or 500 and shoot. PPG seems to still show sctatches with 500 so I go to 600. Metallics and pearls usually need a finer finish, as well. After my 180 cut I usually start wetsanding. Unless it's a quick, small touch up sand, then I might do it dry. But ask 10 different painters, you'll get 10 different responses.
IMO--That's about right. if you're doing a silver or high metallic basecoat color, you'll want a 500 scratch or finer. Straight enamel/Straight urethane's are pretty forgiving, but i wouldn't go below 400 even with single stage solid color Urethane.
Wetsanding will give the best results by far. You'll probably have to either seal the panels- or apply another coat of urethane primer then sand them. You shouldn't have to sand the sealer...so- which do you WANT to do? Also- what are you painting-- material/color?
Try guidecoating again and wet sand it out if you have enough primer on there and its how you like it. Less is more. If its a metallic id go 800, but im just one of the 10.
sounds like you got plenty of primer on there already. i would 600 wet and shoot it. if you go through with the 600 seal it first. good luck.
I would either go 320-400 wet and seal, or 600 wet and shoot. But Mark pretty much hit it on the head there, not much more you can add, except my opinion of course.
