Best Penetrating Oil?
Discussion in 'The Hokey Ass Message Board' started by daredevilcustoms, Feb 9, 2009.
  1. daredevilcustoms
    daredevilcustoms
    from Ohio
    I'm in the middle of restoring a Zenith HP5A carburetor and both the high speed and compensator jets are frozen tight. I've soaked them with Kroil oil without much success. Is there a better penetrating oil out there? Thanks
  2. Rudebaker
    Rudebaker
    from Illinois
    I've had good luck with Marvel Mystery Oil and a lot of "old timers" say plain old diesel fuel works pretty good. A couple of them told me a 50/50 mix of Marvel Mystery Oil and Kerosene will loosen just about anything.
    In a case like yours I wonder if a trip through a sonic cleaner would work to free it up?
  3. choppintops
    choppintops
  4. rusty48
    rusty48
    I like Thrust it's sold by Castle.
  5. yankbuilt
    yankbuilt
    I second Thrust by Castle
  6. scotzz
    scotzz
    Penetrating oil alone is most likely not enough.........try tapping the jets with a hammer (gently)........soak some more, tap some more, repeat.........I got all 4 brake bleeders and some flare nuts loose without damaging anything on my '64 Tempest using this method...........and this is all original **** on the car.........btw.............I used PB Blaster but many seem to think Kroil is better...............I bought Kroil but didn't need to use it............
  7. yoyodyne
    yoyodyne
    PB Blaster is similar to Kroil, some say it's better. In a recent test(forget where to find it right now) the 2 top finishers were Kroil and a mixture of ATF and acetone. One old mechanic I knew swore by #1 oil - sort of like kerosene but thinner, very hard to even keep if from leaking out of gaskets and pipes, he used it for penetrating oil.
    Try boiling the body in water on a stove, expansion might free up the jets.
  8. t-town-track-t
    t-town-track-t
    from Tulsa
    BG has an AMAZING product, if you can find it. I usually flag down the BG guy when I can find him, or go to a garage where they offer BG services, and ask them if they have a can in stock or can get you one next time he comes by.
    Its called "BG In-Force" and it shoots out of the can and foams on the area you apply it. I think this helps it creep into the threads, etc.
    Anyway, I always keep a can in my box, and only use it when nothing else will work, or I know something is REALLY stuck. It has never let me down. Even seen it free up several old flatheads that were stuck for YEARS.
    Kinda pricey, but works well.
  9. 41woodie
    41woodie
    Anyone have an opinion about Kroil vs. Gibbs?
  10. 1rustyhighcab
    1rustyhighcab
    I use BG Inforce at work, its the best penetrant I've ever used
  11. 327-365hp
    327-365hp
    from Mass
    Everybody says Kroil is the best but I can't buy it in stores so I get...
    [​IMG] :D:D
  12. 27 Tall T
    27 Tall T
    from Butler Pa.
  13. scotzz
    scotzz
    eastwood sells Kroil...........$$$
  14. 067chevy
    067chevy
    Kroil is the best I've ever used. I work on anything.
  15. fergenboysinc
    fergenboysinc
    PB is awesome stuff!
  16. dana barlow
    dana barlow
    from Miami Fla.
    PB Blaster .......
  17. I use CRC 556 & PB Blaster they work Great
  18. robt500
    robt500
    from Lex, KY
    I use PB Blaster because it's cheap and I can get it less than 2 miles from my house when I run out. I'm a fan of the hot wrench technique on suspension components but wouldn't want to try anything like that on a carburetor. Good luck, get back to us
  19. born loser
    born loser
    from dallas
    PB Blaster.
    Just paid 20 bucks for a can of Gibbs.Wasn't impressed. :(
  20. Algon
    Algon
    I have never used Kroil but from personal experience I feel Rubachem's Loosey Goosey works better than even PB B'laster and I used to swear by PB. Its expensive and not quite as pleasent as WD-40 but it won't melt your lungs like PB will.
  21. AV8Paul
    AV8Paul
    The best I have ever used is "mouse milk." Cessna Aircraft Co recomends it to lube the wastegate shaft/linkage on their 402C turbocharger. It's the only oil that won't "coke up" and stick from the extreme heat. Think I'm joking? Just google "mouse milk." Pretty pricy too.
  22. 66ragtop
    66ragtop
    PB Blaster works when others have failed for me!
  23. Wheelie
    Wheelie
    from Dallas
    PB is top notch, also stuff called S-ok
  24. garvinzoom
    garvinzoom
    I like Blaster and the product sold by Prolong.
  25. csh68
    csh68
    pb blaster works great and is available from oreilly's and wal mart
  26. I'll 27th PB Blaster.....;):)
  27. Chaoticcustoms
    Chaoticcustoms
    Theres some **** at napa...i think its called freeze off. It works amazing, it actually freezes the part, penetrates in then...TADA. 90% of the time comes right off. I really recommend that product. Everyone ive heard use it is a beleiver now.
  28. 33_chevy
    33_chevy
    from TX
    I like SOAK,works great for me.
  29. NITRONOVA
    NITRONOVA
    I used to work for Volvo (car line). They sell a penatrating oil with the volvo name on it. It is about $8 a can last time I bought it. Spray it on walk away....about 30 minutes later it comes right off.
    I had a rotted exhaust fastener......You know the kind that is a ball of rust that no socket fits.....I had no torch , so I sprayed this stuff on and walked away. I believe it may have been the next day I started on it again and I litteraly used a chennel lock plier and the nut unscrewed right off the stud! All that and with little effort. The stuff seems to quickly generate some heat when you start removing the fastener.......Not alot of heat but obvious some catalyst action.
    By far the best I have used!
  30. Shifty Shifterton
    Shifty Shifterton
    Can you heat cycle the container it's soaking in? Like set it in the sun all day in a heated building, then outside into a snow bank for an hour and repeat a few times?
