Best Penetrating Oil?
Discussion in 'The Hokey Ass Message Board' started by daredevilcustoms, Feb 9, 2009.
  1. ol gasser
    ol gasser
    from here
    Hog wash. But it is not cheap.
  2. harpboys4
    harpboys4
    from So Cal
    pabst blue ribbon and urine
  3. I SMELL SMOKE
    I SMELL SMOKE
    P.b. Blaster a mechanics best friend
  4. Fighter-of-Wars
    Fighter-of-Wars
    We use Panther Piss(PB Blaster) for everything around the shop. Works pretty good, but for some reason we are always out or there are just a few drops left in the can :rolleyes:
  5. partsdawg
    partsdawg
    from Minnesota
    Chrysler heat riser lubricant.Has graphite in it.Like the Toyota stuff just sprat it on and let it set for 20 minutes.
  6. kevinc
    kevinc
    from highland
    freeze off. sounds cheap but works excellent
  7. bigdog
    bigdog
    Kroil is #1, pb Blaster#2. I used to buy Kroil by the gallon when my shop was is business.
  8. Jersey Meathook
    Jersey Meathook
    Yup.
  9. Mopar Mama
    Mopar Mama
    from Boise, ID
    Another vote for PB Blaster. Got the bleeder screws loose from my really really corroded wheel cylinders.
  10. oldsman71
    oldsman71
    again pb and kroil.
  11. djkemerling
    djkemerling
    from nebraska
    tried gibbs on my corroed spot lights worked great, little expensive but worth it
  12. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    PB Blaster it's what makes the world go round (really it does)...Either that or JB 80...Sold by the Justice Brothers guy...not sure if they still sell it. But we've got cases of it at the shop...It's got a unique smell but it works great....PB is my #1 though...you can soak an engine in that **** come back in 20 minutes and it'll be runnin'...Think I'm kiddin' try it.
  13. billylo
    billylo
    You may not believe it but if you soak it in Coca Cola it will unstick anything. I had an old timer tell me to pour it into a motor to unfreeze it. It worked when nothing else did. My 2 cents.
  14. JRRoberts
    JRRoberts
    from Madison WI
  15. 39 Ford
    39 Ford
    My dad loved PB Blaster (he has deen gone 30 years now) ,he once used it in the cyl's of a 265 Chev. it loosened the rings so well that it smoked like Hell. We kidded him about that for years.
  16. Flatheadguy
    Flatheadguy
    "Mouse Milk"......and "Kroil"....always work for me.
  17. KKustoms
    KKustoms
    Kroil gets my vote as well, also works great for cleaning firearms!
  18. ol gasser
    ol gasser
    from here
    Use to work until the late 70s when the formula changed . When it really had coke in it.
  19. RATGASSER
    RATGASSER
    from Lawton, OK
    Sea Foam makes one that I use when PB fails, but is about 7 a can. Has anyone ever tried electrolytic? It was in Rod and Custom May 07.
    Ricky
  20. fab32
    fab32
    Gibb's Brand. Amazing stuff. Contact Roadsters.com for information.
    Frank
  21. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
  22. strombergs97
    strombergs97
    PB, is the best..first strike the nut or bolt to shock it, that will give it some fine cracks in the threads. Remember is must wick its way down the threads so be patient.
    Duane,.
  23. Another PB Blaster fan.
  24. daredevilcustoms
    daredevilcustoms
    from Ohio
    wow, great thread. I'm going to try some PB blaster, then heat and cool the br*** body of the carb. Thanks!!!!!!!!!!
  25. NITRONOVA
    NITRONOVA
    Update on that Volvo oil..........it contains isobutane and propane according to the MSDS sheet.
    The MSDS also warns of frostbite and freezer burn if contacted on mucus membranes or if enough gets on the skin. I have gotten some on the skin before and not had a problem so they must mean large quan***ies.
    This stuff is incredible! I challenge you guys to buy it .....See for your self
  26. I did PB Blaster on my carb studs on the rusted intake I got. Also used it on the studs of the exhaust manifolds and they had been in there for 50 years. Sprayed and let it sit and did this for about a week. Every time I walked by them I hit it with a squirt. Heated the exhaust studs and everything came right out.
  27. modrod
    modrod
    For the price and availability....PB Blaster. It may not be the absolute best, but you don't have to mail order or find a airport or swedish car dealership to get it.
    The only problem is if you don't use it all in a couple of weeks or so, the can loses it's pressure. A guy at a machine shop, that uses it, told me that it works so good that it penetrates it's own seals in the can and allows the propellant to escape.
    I end up with a third of a can trapped inside. I drill a hole and drain it in my old Cragar lug nut mug and apply it with a 1" brush. I actually don't waste that much that way.
    And I agree with the method of shocking it first, apply the stuff, and shock it again.
    You can buy it by the gallon too!
  28. jdj9410
    jdj9410
    from Paris TX
    PB blaster and Loosey Goosey are my picks but that freeze off from NAPA sounds real interesting.
  29. Shifty Shifterton
    Shifty Shifterton
    got me interested... Earlier you mentioned heat upon removal. Are you sure that's not the normal heat from turning threads that are gunked up?
  30. retromotors
    retromotors
    Haven't got to try this myself, but getting excellent reports from several buddies who have been around a long time and tried lots of different ****.
    Fairly pricey, but supposedly works so good it lasts a long time. (Like the old Brylcreem ads ... " a little dab will do ya")
    Also reported to work very quickly, no extended soaking required.
    Check your local motorcycle shop or online.
    Bel-Ray 6 in 1 Multipurpose Lube
