water in oil and oil in water what are the causes??!!??
Discussion in 'The Hokey Ass Message Board' started by borndead327, Feb 10, 2009.
  1. borndead327
    borndead327
    in my 53 ford customline someone sometime ago in a galaxy far far away put a 250 ford straight six in it. i pulled the radiator cap an blam a milkshake.......pulled the oil filter the same ****
    tonight i ran a compression test and all the cylinders are the same
    80psi.....is that low or normal for a 250 ford motor?? the motor is a 71.
    what else besides a headgasket would cause the oil water mix?
    thanks for the help
  2. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    head gasket, cracked block.... Jason
  3. hotrod-Linkin
    hotrod-Linkin
    busted block,busted head or head gaskets..take your pick.
  4. TurboHaddix
    TurboHaddix
    A bad radiator can cause this if it has an oil cooler built in.
  5. borndead327
    borndead327
    nope just a ****** cooler
  6. borndead327
    borndead327
    its not reddish so i cant suspect radiator
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    bad trans cooler will not affect the oil in the crank case,(only the radiator will show it) by you saying you pulled the filter on the engine and found this **** in there too..i would say Head gasket, or broken block or cracked head
  8. chaddilac
    chaddilac
    Yea pull the heads, check the gaskets, then rotate the ***embley and check the cylinders. If it's neither it's deeper in the block!
  9. borndead327
    borndead327
    when i pulled the plugs none were soaked in water
    i use my video scope and checked each cylinder and saw no clean piston
    they all had the same carbon buildup
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    was the car flodded (in deep water) at some time in its life?
  11. Derek Mitchell
    Derek Mitchell
    It's not a leak into a combustion chamber, so you won't see anything in there. It's the head or block cracked, or a blown head gasket.
  12. borndead327
    borndead327
    i honestly coulnt say
  13. Derek Mitchell
    Derek Mitchell
    That wouldn't explain oil in the radiator.
  14. borndead327
    borndead327
    ok yall im off to pull the head off see yall tomorow for an update
    thanks for the help
    god i love the hamb
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    maybe you have a flood car from Katrina?
  16. moter
    moter
    has it been overheated? or sat in cold weather below 32 with just plain water?
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    ahhh ****..your right..its late time to go to bed:D
  18. borndead327
    borndead327
    i would have to say yes
    it was waay out in the hill country
  19. HOW MUCH water in the oil?
    Is it actually liquid under the oil? or is it just a tan or milky goo buildup inside some vent p***ages?
    If you don't actually have a liquid layer under the oil in the pan, you might simply have a super-moisture condition due to too many short errands without enough time for the engine to heat up and boil off the moisture.
    You would be amazed at how much steam is created by a cool running engine that hasn't warmed up yet.
    Enough cool short runs, especially on a high mileage engine, and you can get quite a lot of water churned into the oil.
    If that's the case, an immediate oil change and a few 20 mile trips could clear it right up.
    MAYBE......
    OOPS, I read the letter again. It does sound more serious.
    Long ago I cleared one of those up by using some "heavy duty block sealer".
    It doesn't always work in all cases, but it may be worth a try to get you by for a long while.
    No matter what you do, change the oil right now. You may prevent bearing damage if you keep the oil good and clean.
  20. chevyshack
    chevyshack
    I use to own an 85' ford crown vicky LTD. The oil always looked milky in it. It was my grandmas car she bought new. Never did figure it out. I just lived with till I sold it years later. My uncle has same problem in his 78ish mustang pace car. Must be a ford thing. Neither of us found any of the above mentioned symptoms and he had his mustang gone thru by 2 different machine shops.
  21. Special Ed
    Special Ed
    Sounds like a head gasket to me. At least that's where I'd start.
  22. hotrod-Linkin
    hotrod-Linkin
    i think that's all been said....maybe we need to start a poll
  23. Busy B
    Busy B
    from Kalama, WA
    More than likely a head gasket, other than that probably a cracked head or block.
  24. moter
    moter
    Then it might not be worth trying to find out what happened just look for another engine. You could spend alot of cash and time trying to locate the problem if it is not visible onintial teardown..just my 2 cents ;)
  25. blown green t
    blown green t
    Sounds like time to upgrade. Pull that boat anchor out and put a V-8 in! Get a fox body mustang for a donor then you could have a 302 / 5spd combo. I have seen some good runners for under $1,000. Pull the motor and trans and part the rest. You could have the whole swap done and be into it for less than a grand.That would be way more fun to drive and it would still be all Ford.
    My two cents.
  26. borndead327
    borndead327
    i just pulle the head off it took an hour
    when i pulled that heavy f*&ker off i seen a NEW gasket and no thermostat
    so i am going to take the head to get checked out at the machine shop
    here a pic
  27. hotrod-Linkin
    hotrod-Linkin
  28. JohnShaft
    JohnShaft
    from Tejas
    Wait, it had a new looking gasket? If you haven't had the car a long time I'd say someone sold you one with a warped head from a past overheat. They could easily have used the thickest gasket available when they found the problem to make it run long enough to sell it.
    Reason I say that is that I used to build a few of those family of engines way back in my Mustang days and a warped head from overheating was not uncommon.
  29. borndead327
    borndead327
    new looking........no a new gasket
  30. squigy
    squigy
    from SO.FLO.
    Probably a crack in the head or bad head gasket....
