1964 Buick LeSabre power to manual brakes help?
Discussion in 'The Hokey Ass Message Board' started by 66GMC327, Feb 4, 2009.
  1. 66GMC327
    66GMC327
    Building a 64 Lesabre drag car and the power brakes is not needed. Looks like the booster is mounted to a plate which is mounted to the firewall. I want a dual manual master cylinder in its place. Has anyone done this swap? Thanks
  2. choppintops
    choppintops
    It's a pretty heavy car (we have a 63), I would keep the power brakes.
  3. Pir8Darryl
    Pir8Darryl
    X2... Some 80's GM cars had those nifty 12 volt vacuum pumps. you could pick one up cheap to compensate for the big cam.
    I would look into putting a better M.C. on it tho... The single cylinder "jelly jars" scare the hell outa me.... Bad personal expirence! :eek:
  4. choppintops
    choppintops
    Or if using power steering, a lot of Ford products used a power steering and va***e master combo unit.
  5. scotzz
    scotzz
    Inline Tube has a dual master cylinder conversion for the smaller '64-'65 GM A-bodies (Chevelle, GTO, etc). Includes m/c, pre-formed lines and new distribution block. I'm doing one now on my '64 Tempest but need a different pushrod (which I found) and the pre-formed lines need tweaking. The distribution block bolts up to existing front and rear lines. This is for manual, drum/drum. Dunno if the larger GM bodies use the same hardware.........the Tempest has 9.5" drums.............I think the Le Sabre has 11 or 12". Take a look at their catalog..........you may find something you can use.
