Hot Rods 60 chevy dash in a little deuce sedan....finally
Discussion in 'The Hokey Ass Message Board' started by mecutem, Feb 1, 2009.
  1. mecutem
    mecutem
    Cutting up tin is the most fun for me. I have a lot more finish work to go but can now see how it will look in this little sedan. I used the gauge surround from one dash and the center from two more dashes. Most of the times it has been done the middle 9 inches or so is thrown out and the two halfs s***ched back togather. I chose to use the two middles for the ends. I now have two ash trays and two radio openings. I think I will run two ash trays(need one if someone has an extra) and the radio on the p*** side.
    I will post some pictures when I get everything one color and retrimmed. I enjoy seeing the rough out work the most here on the hamb so I thought I should share these shots.
    Thanks Kirk (craftyb here on the hamb) for motivating me to work on my long forgotten hot rod project. I have been messin with this sedan for almost 20 years and have not heard it run yet. If Kirk keeps kicking me along I may drive it this year! Steve
  2. mecutem
    mecutem
    heres todays progress..........
  3. S.F.
    S.F.
    Very cool!!!!
  4. dirtbag13
    dirtbag13
  5. dieselc
    dieselc
    from ohio
    Thats crazy looking, I love it.
  6. MercManMario
    MercManMario
  7. unibody
    unibody
    I like the way you centered it, looks damn good.
  8. Working on something along those lines, did you use the stock dash rail? Welded in?
  9. One of best I've seen
  10. mecutem
    mecutem
    tman.......... The plan for the top is to place a 1 inch wide strap under the front dash lip and plug weld the trimmed dash to it. Then make risers under the dash from the original 32 dash holes and weld to the strap. That way the top should be about flush and it will unbolt from the car. Steve
  11. Crafty B
    Crafty B
    Steve!! nice work on the dash...It looks sweet centered up for sure and you better have it welded up and done by the next time I come over...were drivin to the Gilmore show!!!!! HAHA
    Crafty
  12. Gigantor
    Gigantor
    Very well done. The centered orientation is unexpected and groovy.
  13. mecutem
    mecutem
    Heres a few progress shots. Filling the voids really helps the look I think. 2 ash trays and no spot for a radio. The big vent under the speedo is one of the chevy factory air vents taken from the outboard part of dash. Takes the place of where the column was. Its heavy die cast. 3 inch opening in it so a bit too small for a tach. I plan to run the stock harness with ignition and stock switches. I also plan to run the Impala column/wheel with the stock shifter. Time will tell how that works out. I really had my doubts when I started this dash. I feared the centering may goof up the look. Henry designed these cars to have the gauge cluster in the middle right? Thanks for the positive comments. Negative comments welcome too! Steve
  14. Toast
    Toast
    from Jenks, OK
    That looks awesome! I am going to put a 55 Chevy dash in my 31 Roadster, cool to see one done!
  15. 60'shotrod
    60'shotrod
    NICE Lookin' Dash, Man.Looks kinda spaceship like and I like that!
    Nick.
  16. jchav62
    jchav62
    That's killer!!! I like..
  17. 49ratfink
    49ratfink
    59-60 chevy air conditioning parts do well on ebay. that's where I'd put those vents and anything else ***ociated with the AC.
  18. continentaljohn
    continentaljohn
    The Lowone is looking good Steve:D I can't wait to see her on the road. How about some full shot of her:eek:
  19. BlackMagicKustoms
    BlackMagicKustoms
    from Denton,TX
    That's funny I just got done using the same gauge set in the roadster. Good job!
  20. mecutem
    mecutem
    for you John old pictures full fendered picture is about 20 years ago. No recent pics yet with the BBC installed. This little car is so much fun to work on. Steve
  21. mecutem
    mecutem
    I call this sedan little for a good reason. It not very big when compared to stockers. I still fit in it OK though thanks to a drop floor. Steve
      38.1 KB
  22. pan-dragger
    pan-dragger
    looks good, nice work making that fit.
  23. Jigger
    Jigger
    Great idea. It is very cool to see it actually put into practice.
    Nice job!
    Reminds me of this design I drew. A H.A.M.B. member in New Zealand is building it.
  24. 1951bomber
    1951bomber
    from atwater Ca
    why didn't i think of this first ur a genius
  25. man that really looks nice!
  26. B.A.KING
    B.A.KING
    coming from a person who looks at a 59 dash about every day,i must say that is about the best use for one i have ever seen. great design,for-thought. you do know the have a radio block off plate for those things don't you? i have to say that is outstanding. good job!!!!!!
