Hot Rods Found 32 roadster with history???
Discussion in 'The Hokey Ass Message Board' started by Bear Metal Kustoms, Feb 13, 2009.
  1. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    So a guy comes into my shop today and asks me if I know anyone looking for a 32 roadster. I figured it was going to be a gl*** car painted some bright color. Then he tells me that it was a 50's build he got from the original builder some time ago. The original engine was missing (ford v8 ohv) but he has a 50 olds motor and manual trans that he will sell with it.. The car was in Hawaii and he had it shipped here..The doors are molded in as are the rear fenders. The car is heavily channeled over the 32 rails but all the x was cut out and other crossmembers put in.. It has a F-1 box and an original set of MT slicks in very good condition. Dropped A axle and juice brakes..40 ford axle out back. What do you think this thing is worth? It is pretty rough....Trying to get some idea if it is worth the effort to put back on the road.. If there is some interest you can PM me and I can p*** along his info if he OK's it.. I kinda want some idea or guesses of value before I post what he wants for it..I am still trying to decide if I want it or gonna p***....Jason.
  2. Corn Fed
    Corn Fed
    Is it April 1st already?
  3. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    Nope, This is real.... I was out at this guys house this afternoon... He is an older man with a few cars.. He has no interest in this car as he has a 34 vicky, hudson super wasp and a few others he is building.... I have no idea what this would be worth.. When I see 32s that are somewhat stock or restored, etc... that is easy to figure.. But this early home built I am stumped.. Jason.
  4. The37Kid
    The37Kid
    The guys that are more knowledgeable on '32's will post I'm sure. Belt moulding looks odd to me, not a good looking car as is IMO. Wouldn't want to be into it for over $5,000. The cost of shipping it back from Hawaii has nothing to do with its value.
  5. GOONZ
    GOONZ
    Hell Jason, if it's cheap enough you can part it out, I'll take the dash and gauges.
  6. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    Not really looking to part out.. I would probably p*** before cutting it up...I will let you know what happens though... Jason.
  7. 40 & 61 Fords
    40 & 61 Fords
  8. RocketGirl
    RocketGirl
    This is no joke... I was with him this afternoon.. I am his wife. You can kinda see me blur by in the background of one of the pictures..
  9. Hmmm...original 50's hot rod....steel 32 roadster....history or not...its gotta be worth a go at Jason. If the body's not too bad, I would go for it...as long has the guy don't want Barrett Jackson money for it...
  10. HHRdave
    HHRdave
    from So Cal
    Not only is it heavily channeled, it is missing about 2-3 inches along the bottom length of the body (from the cowl to the decklid). It also looks like 2-3" were taken out to shorten the body in length. The only thing I see of any value are the windshield stanchions, if they are in fact original bronze castings, then you could get $150 for those.....
    When the the last time you saw a steering wheel that was as high as the top of the windshield ???
  11. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    The body is not shortened but it did loose a couple inches along the bottom. It is a funky old build. The guy said he had pics of it from back in the day when the builder was running it around..Jason.
  12. Deuce Roadster
    Deuce Roadster
  13. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    It is a diff. car for sure. I know that much.. It came from the island of Molakai. It hadn't been out for years. It was next to the owners house with a palm tree growing through it and covered in plants... Cars in Hawaii must have fenders by law.. It was common for guys to mold them in..
  14. hotrod40coupe
    hotrod40coupe
    Looks pretty rough but I would say between $3000-$4000. JMO
  15. Squablow
    Squablow
    How are people figuring on 3-5K? I thought Deuce roadsters were 20K+ for even ****ty hacked up old ones. So what if the bottom couple of inches is cut off, that's easily repaired. How hard would it be to get the doors opened up again?
    Jim Sibley could fix it.
  16. JimA
    JimA
    That's one of those cars that with 8,000 worth of patch panels and at least 20,000 worth of labor you could make a decent "original" Deuce roadster out of- or you could pay Brookville 12,500 for a complete new body and be done without getting your hands dirty. No way to come out ahead on that one. I bit off the '32 no one wanted once- biggest waste of time I ever experienced
  17. 327-365hp
    327-365hp
    from Mass
    I'm with JimA on this one. Consider the body as s**** and put value on the rest of it. Buy it for the Olds motor and ******. The flywheel for and Olds is very hard to find. Keep the slicks and the gauge panel. Someone will want the rails if they have serial #s. Sell off the front and rear axles and give away the rest. I'd offer $1800 and you might do all right at 2K.
  18. T-Time
    T-Time
    from USA
    I'll have to heartily disagree with most everyone else on this one. The value of this car is in its historic value as a genuine '50s build. Its worth much more than the sum of its parts! To me (as a genuine Model T cheapskate), I'd value it in RESTORED condition in the neighborhood $20K. As it is (with the Olds engine), I'm not sure...maybe as much as $7K on eBay.
  19. HotRod_Joe
    HotRod_Joe
    I'd kill for a '32 roadster, but I wouldn't even think about paying money for something like that. It doesn't look like that body could be saved without thousands of hours of labor. The bottom of the body is gone, the doors are welded shut, the fenders are welded on, that grill shell is junk, and the list goes on. Unless it was a big name or well known build, the historical significance would go over the heads of 95% of the people out there.
  20. Deuce Roadster
    Deuce Roadster
    Hawaii does have fender laws ... **** Scritchfield sold his FAMOUS roadster because he could not use it in Hawaii when he moved there from Los Angeles.
    I love 32 roadsters as much as anyone :D ... but unless you can enjoy this one ... basically the way it is ... it is only worth a few thousand dollars IMHO ...
  21. T-Time
    T-Time
    from USA
    I agree with this. And, I believe this is exactly how this car should be enjoyed. All the talk of "fixing" the body gives me a bit of a sick feeling.
  22. T-Time
    T-Time
    from USA
    I gotta admit that this is right. If the guys on the HAMB don't get it, I guess no one would.
  23. 31whitey
    31whitey
    hmmm...
    If your looking to build yourself a pinched nose highboy, flathead, 39 box, banjo, 750 rears 450 front, etc,etc,etc,....then this is NOT the car for you....PERIOD.
    If you need a value... heres a trivial idea....ASK the friggen owner what he wants and if its within your budget and sounds fair buy it...not to hard.
  24. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Not a 32 expert, but It looks like a ******* 5 window coupe whatwith eveything shortened up and molded in.
    It's a cool survivor though. I agree that you'd have to love it/build it just the way it is.
  25. Harms Way
    Harms Way
    Judging by the cowl and the above the deck lid panel,..... This puppy was the genuine article. seriously guys, even gl*** 27 T body (body only, no floor molded doors and deck lid) starts at like $900.00, And glue it together yourself gl*** 32 Roadster bodies start at $3,000 ! and thats all you get, with everything thats there including the 1932 Ford frame, 40' brakes all around, dropped axle and stock wishbone,.. I would guess 3,500 to 5,000 would be fair,... IMHO
    And another thing,.... I have seen post after post of guys bashing reproduction steel and fibergl*** bodies on here because they "Have no soul !" so here ya' are guys a beat up old body with tons of soul,...... and your arms are to short to reach to the bottom of your pockets,.... that's priceless ! :eek::eek::rolleyes::rolleyes::D
  26. I mean I would build it pretty much the way it is but try to make some tasteful period changes along the way, just to make it look as good as it can look. It's still a '32 roadster from the 50's and we all have seen worse looking rides. That grill shell could be saved too. So was it sectioned or did they just hack the bottom off? Either way I still think it's alright, it was done then how can you debate it. I'd say $3-5000 on ebay maybe, seems like it would fetch less here or in general though. You have to think though finished nicely as an all period correct hot rod 32 it would be worth quite a bit, but that being said how much do you have to put into it to get there? ...Or you could just slap it together and have fun :D
    -Dean
  27. 392_hemi
    392_hemi
    How many people you think want to spend 50k to restore a car that's going to be worth 20k when its done? Especially if it's as ugly as this one.
  28. Kevin Lee
    Kevin Lee
    Super Moderator
    I love historic cars and will be one of the first to say that not every car built in the 50's followed todays formulas for what we call traditional. But I question how much of this car is a "50's build" and... it's ****ing ugly.
    But if someone wanted a 50's version of a Deuce Roadster Bobber Truck then it's perfect for them.
  29. Uptown83
    Uptown83
    Looks pretty rough in the pictures and pictures usually hide all that. Im working on a 32 5w where i spent around 4500 in patch panels. I dont regret it but the body only cost me 1500. So i guess im in the body for around 6000. Anymore than that and I probably would have p***ed on the body. Im guessing around 5-3k. I would think you would spend 5k+ on patch panels.
  30. rick finch
    rick finch
    Ditto, what Kevin Lee said....... That thing is crude even by 1950's standards!:eek:
