When is a Model A drum under size?
Discussion in 'The Hokey Ass Message Board' started by Brendan1959, Feb 15, 2009.
  1. Brendan1959
    Brendan1959
    Can someone tell me what thickness a model A drum can be machined too befor its under size.
    Thanks
    Brendan
  2. Unkl Ian
    Unkl Ian
    You mean Oversize ?
  3. Brendan1959
    Brendan1959
    You say potatoe I say patio or something like that, when are they ready for the bin.
  4. 4ever4
    4ever4
    from Texas
    Cast iron --or stamped steel? Cast iron can go .050" safely. The stamped steel are not supposed to be machined. Consider using new cast iron drums that look like the original drums.
  5. mbshafter
    mbshafter
    from Detroit
    The minimum "safe" wall thickness for steel drums is .120". Anything less than that I throw on the s**** pile.
  6. Brendan1959
    Brendan1959
    Thanks
    .120 now I have some thing to look for.
    Brendan
  7. fiftyv8
    fiftyv8
    from CO & WA
    Bredan the trouble with model A sheet metal brake drums is that they get hot and distort under heavy braking and expand out so they become more over sized than when cold so you loose your brake shoe adjustment when hot.
    If you want mechanical brake may I suggest you find yourself a 1935 front axle complete and install it onto the model A radius rods, that way you get a lower front, open cast iron brake drums and slightly bigger diameter drums, just need to make a steering arm to go onto the spindle.
    All the lever will do right up.
