Projects Everybody needs a shop truck, let's build a 49 GMC
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Sep 29, 2008.
  1. the-rodster
    the-rodster
    I am embar***ed to say how much time I have invested in mounting this gas tank.
  2. the-rodster
    the-rodster
    Next, I picked up some axle pads at TSC, made careful measurements, took pinion angle into consideration, and welded them up.
    I also ran a tube across the frame rails for the shock support, mounted the shocks, and fabricated the lower axle plate.
  3. the-rodster
    the-rodster
    Since the rear is ****oned down, I moved to the front, and placed my core support and inner fenders in place (it been cold, so I haven't had a chance to blast and prime them)
    The inner fenders have to be trimmed to clear the upper A arms, and I plan on filling the extra "bump" for the steering box.
  4. the-rodster
    the-rodster
    The first thing that I noticed, is that my late model master cylinder/comb valve touched the inner fenders.
    I could reroute lines, etc. but I figured it would be easier to just put a "bump" in the inner fender under the master cylinder.
    I marked it for clearance.
    Then pushed the metal in, and made a filler panel.
  5. the-rodster
    the-rodster
    Next, I ran all the brake lines.
  6. Rehpotsirhcj
    Rehpotsirhcj
    Great build.
    Looking forward to seeing more.
  7. NealinCA
    NealinCA
    Your build is looking real nice...you are making great progress.
    Here's G-78-15's and L-78-15's on 15X5.5 and 15X7's for the bias ply look...
    and 205-75-15's and 235-75-15's on 15X6 and 15X7's forthe radial look...
    Neal
  8. the-rodster
    the-rodster
    Yeah, Neal
    I forgot to update the thread with my tire choices, you're right, I went with 215/75 and 235/75 with 1 3/4 " whitewalls, that I may enlarge to wide whites.
    Got 'em for $298 mounted/tax out the door.
    Rich
  9. ratster
    ratster
    nice work Rich
  10. 53olds
    53olds
    you should put some patina on like mike lavears and a bunch of others.
  11. burger
    burger
    Rich,
    Great build as usual and thanks for taking the time to do***ent it for us.
    So I spy yet another carefully positioned High Life bottle. I'm starting to suspect that they sponsor you and those bottles are actually product placement!!
    Ed
  12. the-rodster
    the-rodster
    Next, I started shortening the running boards.
    I made a cut in a strategic location, then starting measuring to see how much needed to come out.
    Then clamped the pieces together...
    S***ched together....
    An hit with a flapwheel.
  13. the-rodster
    the-rodster
    This past weekend was super nice, so I spent a full day sandblasting, and priming the fenders and running boards.
    Just to see how things were going to fit, and for motivation, I threw the fenders on the truck.
    I'm really digging the stance, and the front should come down even more with the rest of the sheetmetal installed.
  14. the-rodster
    the-rodster
    Looks like everything is gunna fit.
    The stock clutch fan wasn't gunna fit, so I bought a new reverse direction fan, and a two inch spacer.
    It sits kinda low on the radiator, but I think it will be OK.
    I HATE electric fans.
  15. AA/Fuel34fordpu
    AA/Fuel34fordpu
    WOW this is a great threat for a do it your self econo hauler.
  16. Swedesled66
    Swedesled66
    from Slough, UK
    I have a 53 GMC panel truck and this thread is proving to be very useful. Looking forward to any updates.
  17. sloppy-ollies
    sloppy-ollies
    from Jersey
    Just read this thread from start to finish, great work! Looking forward to reading and seeing more:)
  18. uc4me
    uc4me
    you are my hero....I have had my 55 ford f100 for 2 years now and have made nowhere near the progress you have...hats off to you man
  19. Harrison
    Harrison
    Ain't nothing lackin' when you're Cadillacin'!!!!!
  20. the-rodster
    the-rodster
    Chevy small block, pulled from a Cadillac, with Studebaker valve covers, and Oldsmobile air cleaner.
    What a ****rel.
    Rich
  21. Nice work, a cool truck!!!
  22. slimneverdies
    slimneverdies
    from Miami, Fl
    How much did you end up cutting the running boards to make them shortbed boards?
  23. the-rodster
    the-rodster
    Same distance you take out of the frame and bed, little over 9 inches.
  24. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    Damned nice build! Keep the updates coming.
  25. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Yeah, holy **** do you guys amaze me.
  26. the-rodster
    the-rodster
    I can't believe that I haven't posted and update in over a month.
    The small things have been taking FOREVER.
    stainless headers...
  27. the-rodster
    the-rodster
    Fabbed up some four inch lowering blocks...
  28. the-rodster
    the-rodster
    Running the fuel lines...
  29. the-rodster
    the-rodster
    transmission cooling lines....
  30. the-rodster
    the-rodster
    The steering was a *****.
    First the old fatman crossmember didn't have the tabs welded on to mount the rack, so I had to pull the motor, fab the brackets, and put the motor back in.
