1930 tudor chop continued
Discussion in 'The Hokey Ass Message Board' started by scarr345, Feb 17, 2009.
  1. scarr345
    scarr345
    from michigan
    heres some more pics i have been workin on it a lil each day. i had a hell of a time gettin the rear vertical belt line to line back up but i finally go em pretty close more pics to come soon
  2. blackout
    blackout
    Looking good. Keep at it.
  3. dirybyrd
    dirybyrd
    how much did ya take out?????????
  4. scarr345
    scarr345
    from michigan
  5. Try cleaning a little wider area around the weld INSIDE AND OUT and also work on making the cuts more precise. It will make your like MUCH EASIER.
  6. scarr345
    scarr345
    from michigan
    ok, its the first time i have chopped a top. thanx for the advise. the cuts started out real close but i didnt want to make any relife cuts so they ended up a lil wide on the back. i think with a lot of time i will be able to get them metal finished (hope)
  7. MercManMario
    MercManMario
    Smack dab in the middle of a chop on my '50 Merc myself. Great job....you seem to be making quick work of it. I am realizing that its not so much the tack welds as it is the finished welds that are so time consuming. The best advice i can give is to be patient and ENJOY IT!
