Buick motor
Discussion in 'The Hokey Ass Message Board' started by SoCal Merc, Feb 17, 2009.
  1. SoCal Merc
    SoCal Merc
    from SoCal
    This just got dropped at my friend's shop for a rebuild......
  2. Pir8Darryl
    Pir8Darryl
    Cool... Any history behind it? Ex drag motor or something?
  3. SoCal Merc
    SoCal Merc
    from SoCal
    He cracked it open today. Isky cam. The magneto is wasted, one valve cover had been left off. Sad, when he pulled the valve cover off the other side, it looked it just had a valve job before setting outside for all this time. The owner said it came out of a boat.
  4. MyEvilTwin
    MyEvilTwin
    Roller cam? that would be a nice find for sure. What displacement is it? 401s seemed to find their way into a lot of boats. Not super common to find injection on a boat is it?
  5. SoCal Merc
    SoCal Merc
    from SoCal
    It does have a roller cam. I'm going to check his progress out when I stop by there later.
  6. SoCal Merc
    SoCal Merc
    from SoCal
    Learned it was pulled out of a sprint car, which was raced by a dealership in Iowa. 425 ci. The ISKY roller cam is a 5 cycle, 7000 series(?). Anybody know the specs? They went by ISKY, but they didn't have a catalog that went back far enough to look it up. ISKY is positive they have old cam cards somewhere in the shop for it. The owner of the motor doesn't even have anything to put it in, so I am not sure what he is going to do with it. Be nice in my "A" 5W coupe!
  7. MyEvilTwin
    MyEvilTwin
    Some of the old mail order catalogs listed cam specs with the cam listings. I think Honest Charlie's used to back in the 60s.
    Sometimes it wold be a 7000T 7000R or just 7000. each would have a slightly different grind/lift.
  8. rdachsdog
    rdachsdog
    from michigan
    I could use the mag base for that fuel pump drive if he doesn't plan on using it, or if anyone else has one.
  9. NAILHEAD JONES
    NAILHEAD JONES
    from Lomax ILL
    nice motor good history need a good home
