How to do hardtop conversion??
Discussion in 'The Hokey Ass Message Board' started by Scallop, Feb 17, 2009.
  1. Scallop
    Scallop
    I am possibly doing a hardtop conversion on a 48 ford sedan I have and I was wondering where people get the stainless that goes around the windows, I know its custom made but I can't seem to find any info on what people are using.
  2. banditomerc
    banditomerc
    iF YOU ARE MEANING HIROHATA STYLE HARDTOP...THEN YOU ARE REFERING TO THE WINDOW FRAMES,tHESE CAN BE MADE UP USING 5/8 CHANNEL,SIMPLY M***AGE;) TO THE SHAPE OF THE OPENING.THIS IS NOT AN EASY OPERATION,BUT CAN BE DONE BY A NOVICE I`LL BET...JUST TAKE IT SLOW.GOOD LUCK:cool:
  3. Scallop
    Scallop
    How is it attached to the window? is it just glued on? also what do you do about the weatherstip between the windows?
  4. banditomerc
    banditomerc
    The channel is actually the window frame and is stationary.if you mean on the other hand , frames that go up and down...well that is totally different.you would need to fabricate or scavenge a car at a junkyard for frames similar to what you need.
  5. Scallop
    Scallop
    I know the mechanicals of the windows but I am just concerned with the chrome/stainless frame around the gl*** itself.
  6. Kustom7777
    Kustom7777
    from Austin, TX
    just like on the hirohata merc...i never knew those frames were stationary until recently
  7. banditomerc
    banditomerc
    THE GL*** ITSELF GOES UP AND DOWN AND THE FRAME STAYS IN PLACE.i IS SECURED TO THE DOOR USING SCREWS OR SOME OTHER WAY OF SECURING IT.
  8. banditomerc
    banditomerc
    LOOK AT MY THREAD "I WANT MY CHOP",I AM CHOPPING MY `48 AND LEAVING THE FRAMES IN PLACE.lOOKS BETTER THAN CHROME FRAMES...IN MY OPINION.
  9. hotrod-kustom
    hotrod-kustom
    I take on my Ford 46 Cupe inside back from a cupe who have ht and make it to work before I welding fender. more easy if you can see it works from outside.
    After I was finnished i remember Ford 55-56 CW have thers inside mecanism bolted hmmits have been much more easy to use this.
    Problem its more side windows on 40s body see on a conventible how doors looks.
    The side of body its not straight you see that after you cut, same with roof .
    I havent make 100% straight but more like conventible.
    Dont forget do side harder down on floor and under floor.
    For the wondow frame you ask about use stainless and that its not hard to do self or live to some how do after your size, but try do self first.
    Good Luck
  10. cool57
    cool57
    Gl*** setting tape is used to insulate the gl*** from the metal. Used on hardtops thru the 50s and into the 60s. Used on many cars' vent window frames. Check with auto gl*** company/shop.
