what trannys have you used that worked out great?
Discussion in 'The Hokey Ass Message Board' started by pie pie, Feb 17, 2009.
  1. pie pie
    pie pie
    from missouri
    just curious to what all kinds of transmissions everyone has used both manual and autos and how well they worked out. primarily for sbf but what all different types of 4 or 5 speeds worked great and took some abuse?
  2. el Scotto
    el Scotto
    from Tracy, CA
    Anything made by Chrysler has been good to me, except for one 904 automatic which failed the day I bought the car....
    All my GM made automatics seem to fail prematurely, although I'm pretty impressed by the amount of abuse my S-10 T-5 stick shift has taken.... ;)
  3. George
    George
    Havehad great results with C4, C6, FMX, & Mopar 904 & 727
  4. blackout
    blackout
    Muncies and T-10's work fine for me.
  5. dirybyrd
    dirybyrd
    C-6 is the best auto trans Ford has made, in my little opinion.........The TH400 is a great GM ****** also............
  6. The Shocker
    The Shocker
    Toploader 4 spd is the greatest production 4 spd ever made period.I should have broke the one i had many times and it never gave it up.Shifted like silk in town and would drop in the next gear on the strip at 6500 every time with my foot on the floor.I broke rearends ,clutches ,etc , but the trans was bullet proof ...
  7. Drive Em
    Drive Em
    I like the T-5 in my '63 Ranchero, shifts smooth as silk. The B/W Super T-10 in my Galaxie is awesome also.
  8. BW T-85, T-10, C-6 & the ZF in my Ford truck.
  9. art.resi
    art.resi
    Top loader ford from 68 mustang shoud take anything you can hit it wit
  10. metal man
    metal man
    Can't go wrong with a C4 for a sbf . Small,light and will take a ton of power . C6 is good too just really big ,eat up a lot of cabin space .
  11. pie pie
    pie pie
    from missouri
    a toploader is a little out of my price range. what do t10s and t85s come out of? i have an aod in a mustang and a c4 sitting mabey for the next project. cant decide what i wanna use
  12. The Shocker
    The Shocker
    I see Toploaders occasionally on Craigslist for $300 -$500 .Sometimes with a shifter and Bell Housing to boot.T-10's arent as sought after as the Super T-10's.I think the T-10's are the early versions and are part aluminum and cast iron.The supers are all aluminum case and i think they came in early to mid 70's Vettes and Camaros.Not near as strong as Toploaders though ,from what i have heard.I am i bit bias ,cuz i was real impressed with the Toploader i had in my Falcon ...
  13. AnimalAin
    AnimalAin
    I had a C4 in my roadster (and one in my coupe, too) that worked like a champ for a long time (20+ years) with essentially zero drama. When the motors got replaced, both cars got AOD transmissions. I really like the combination of short gears around town, and tall gears on the highway.
  14. pie pie
    pie pie
    from missouri
    ill ave to keep an eye out for one
  15. Billa212
    Billa212
    from Milwaukee
    C6 is a monster if you can find something for your left foot to do...mine gets restless leg syndrome
  16. hotrod-Linkin
    hotrod-Linkin
    all that didn't explode..
  17. d2_willys
    d2_willys
    from Kansas
    c4 transmissions are good strong boxes that are very easy to work on and are easy to come by. Performance parts are available too. From past experiences they are a good trans for the money and for SBF's.
    Chrysler transmissions are pretty solid, as are turbo hydramatics of all series. My favorite is the old dual range hydramatic from the early 50's, virtually bomb proof and were used in WWII tanks. Strong, but heavy as hell.
  18. The Shocker
    The Shocker
    Cant beat the gear ratio of a small block Toploader either with that 2.78 low gear.My 56 Chevy has a Big Block Muncie and i'd trade it in a second for a Toploader and adapter kit from Ford to Chevy .If i run across a Toploader cheap ,i shoot you a pm ,if your intersted ...
  19. metal man
    metal man
    I just sold a ford AOD today! Oh well you're too far away anyway.I bought it for my '40 and changed my mind due to size.It has a C4 now and would have had to cut frame for aod .If I were just now building the car, I would use an aod so I could run a lower gear . If you get one , make note of the year . After a certain year( 1990 I think ) they require a computer .
  20. pie pie
    pie pie
    from missouri
    how high are your rpms at highway speed with the c4?
  21. vertible59
    vertible59
    I put an FMX in the 50 MERC I built several years ago. Best trans I ever had, because it worked super for years and, best of all, it was a freebe.
  22. pie pie
    pie pie
    from missouri
    the aod that i have in my other car is the non computer controled one and its out of a 91 mustang and it works fine so far
  23. metal man
    metal man
    It's easy for me to remember , 72 mph is @2700 rpm . That's with a 3.5:1 gear and a 31" tall tire .
  24. metal man
    metal man
    Yeah,I had an FMX in a daily once . Forgot about that one. It worked great for 100k miles or more . They have an iron case . Drove just like the C4 .
  25. pie pie
    pie pie
    from missouri
    i dont even know how tall of a tire i can get to fit
  26. metal man
    metal man
    :)If that post war coupe is what you're building, you can fit a 31" tire .Bottom line, You'll be happy with either a C4 or an AOD or a C6 if you have room .Then there are your T5's with od if you want a stick . We could go on and on but I'm going to bed !
  27. pie pie
    pie pie
    from missouri
    cant decide i already have the c4 but would like to go with 3 pedals but want a resonable priced one that will take some abuse.
  28. straightaxlenova
    straightaxlenova
    Top loader Ford, or Chrysler A833 4 speeds will handle full throttle powershifts no problem.
  29. 30dodge
    30dodge
    from Pahrump nv
    Mopar 727 with a shift kit ,never a missed shift ,just broken motor mounts and busted U joints.
  30. man-a-fre
    man-a-fre
    727's are bullet proof.
