how did they use to do a solid alex conversion on the old gasers?
Discussion in 'The Hokey Ass Message Board' started by male hauler, Dec 13, 2008.
  1. chris55
    chris55
  2. Weasel
    Weasel
    That might be because MAS makes them 'alexes' for Speedway.:D
    I'll stick my neck out and say that I have never understood why Henry Ford chose to go transverse leaf and cross steer - see my signature. Knowing Henry's reputation it must be because he thought he could save a dime. I think that it is a *********** of a suspension system, which unnecessarily overcomplicates a simple issue, to which there is a simple solution. The factory parallel leafs/semi elliptic on my Willys work very nicely than you - simple and easy. Why would anyone voluntarily want to go to a transverse leaf straight axle retrofit on an IFS car?:confused:
  3. Mr Haney
    Mr Haney
    I have to agree with weasel here. DO NOT run the transverse set up. stick to paralell leaf springs, if you must make this conversion. Guy I know Gene Web put transverse under his 55 with hairpins, hit the brakes and folded them. His hairpins were mild steel chrome plated. His repair was to install stainless steel hairpins with gussets. still a ****ed up set up in my opinion.
  4. Little Wing
    Little Wing
    from Northeast
    How come there are'nt any done leaving the old frame intact ?
  5. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    Not to high jack the thread, but my fiance has a '51 F1 with discs on her I beam axle. I've been thinking of tearing it out and replacing it with an IFS set up. Would the original axle be a decent donor for a g***er project? It's not truly a "straight" axle. It does curve a bit, but I thought it might be usable for that. Any thoughts? It may help the OP answer a question or two.
  6. notrod13
    notrod13
    from long beach
    you gotta talk to roger at voodoo kustoms ... he can set you straight .. he has everything you need and knows the history... pm me and i will give you his number ...
  7. Weasel
    Weasel
    A lot of people confuse 'straight axle' with solid axle. Many g***ers used a solid axle with a slight drop - Econolines have a drop, as do stock 1933-1942 Willys, but have been used many times. It's really a question of how much you want your car's nose to hemmorhage.
  8. Larry T
    Larry T
    Probably because a big part of the reason for putting an axle under the car was for weight savings on the front. A couple of 2X4 stubs weigh quite a bit less than a stock front frame with the big crossmember in it.
    And while we're on the subject, why use a stock I beam when a tube axle is lighter? Yea, I know the answer. But if you're going to the trouble of cutting you're car in half, why not spend a little more and make it as light as possible?
    Larry T
  9. chris55
    chris55
    Depends on the car, but most of the time the frame had a big crossmember. Not only was it heavy, but most of the time rode very close to the staight axle. Also the front of most frames, were not strong enough to handel having the springs mounted to them. I have seen a few built that way, but they look kinda strange.
  10. metalmike13
    metalmike13
    from Glass City
    put Alex's name on the ***le and transfer it:)
  11. d2_willys
    d2_willys
    from Kansas
    Correction to the above post on how to do it:
  12. thebrassnuckles
    thebrassnuckles
    /\ ha ha ha, very nice, subtle. i like it.
  13. Hustler
    Hustler
    I have 54 customline I just bought a complete 91 Comanche axle for a $100 now I just need to figure out what I am doing for spring hangers. I have some old 49 ford spring from a buddy that I plan on running.
  14. male hauler
    male hauler
    With my build I got a second frame and cut it off in front of the body mounts and built a new front section out of 2x4 sq tube
  15. male hauler
    male hauler
    Wow I just answered my own post lol
    s55mercury66 likes this.
