O.C. 235 chevy help
Discussion in 'The Hokey Ass Message Board' started by MOBBING50s, Feb 19, 2009.
  1. MOBBING50s
    MOBBING50s
    from orange CA
    ok so i live in orange, i have a 53 belair with the 235/powerglide in it and its running really off. i turn it on and it wont idle nice and wont stay on for more then a min or will turn off when i put it in gear. i need someone to come out to my house and help me fix this prob. i really am lost when it comes to these motors. 17146543716 thanks art im planning on working on it all weekend
  2. MOBBING50s
    MOBBING50s
    from orange CA
    i will also pay you for your time
  3. shoprat
    shoprat
    from Orange, CA
    Try Tom's Automotive at Gl***ell and Taft I think. I see alot of older cars around
    his shop
  4. hotrod-Linkin
    hotrod-Linkin
    check the spark advance canister on the distributor if it's busted internally.**** on the hose and see if mechanism moves.if not....go buy one.
  5. 53sled
    53sled
    from KCMO
    1. check the vacuum advance line for leaks,
    2. chevk for burned up points,
    3. check for loose intake bolts, leaks,
    4. I recommend you get a langdon's adapter and put on a holley weber carb, mine ran so much nicer and they are easy to run 2 or 3 carbs since they have built in progressive linkage.
  6. LastMinuteMark
    LastMinuteMark
    from So. Cal.
    what have you done to it so far?? have you changed the dist cap, rotor, plugs, wires, points, condensor??
    not familar with those carbs but does it have an electric or manuel choke, check that the choke ****erfly isnt sticking open or closed.
    how close is your fuel line to your exhaust or other hot things, any fuel filters in the carb or anything you dont know about, maybe blow some compressed air into the fuel line that runs from the fuel pump to your tank
    how is your engine wiring?? is the motor/trans grounded properly??
    just a few questions that come to mind....good luck
  7. Bill Schickling
    Bill Schickling
    I have had this issue before. It was always fuel related. Check fuel filter, Carb float. Take carb off and clean well. **** from the gas tank can mess up the carb easily.
    The other suggestions of checking ignition related items is good advice as well.
  8. MOBBING50s
    MOBBING50s
    from orange CA
    ok gas tank was cleaned out new fuel lines, motor was completly rebuilt form the ground up, dis. looks new still and wires too, carb is new also(prev. owner did all this work and the car only has about 600 miles on it since then but ive had it for almost a year now)
    only thing i can see that isnt new is the vacuum adv unit and it does feel like theirs a leak coming from the arm that makes the dis. trun. will that really make the car do that? also it sounds like its missing and it idles kinda high and the idle screw is backed out all the way.
  9. hotrod-Linkin
    hotrod-Linkin
  10. squirrel
    Is the choke working right? the plate inside the top of the carb should be closed when it's not running, and the engine is cold. When it starts up, the plate should open up a little bit, and when you rev the engine it should open more, and when it's hot it should stay open all the way.
    What does it do?
  11. OLLIN
    OLLIN
  12. MOBBING50s
    MOBBING50s
    from orange CA
    Well I don't have the choke hooked up its just blocked off and its getting fuel I can see it down the carb
  13. 53sled
    53sled
    from KCMO
    vacuum leak. that is why you have to screw the idle all the way out to compensate. use a propane torch, not lit, and just let it blow gas out all along every place a leak can be. you'll find them all.
  14. MOBBING50s
    MOBBING50s
    from orange CA
    ok so i got a new vacuum unit how would i go about changing it out? thanks for the help
  15. evil1
    evil1
    check the timing
  16. Goozgaz
    Goozgaz
    Something new everyday.
    Not sure how this works.
  17. panic
    panic
    Vacuum leak.
  18. hotroddon
    hotroddon
    Tom's place is actually called "Auto Tech" South West corner of Gl***ell and Taft. He does a lot of work on old stuff and the OC Labor Day Cruise giveaway car each year.
