I have the rear end out of my '49 chevy fleetline, it is a torque tube, and was rebuilt by the previous owner, 20 years ago, but has no miles on it since then (divorce, storage, etc). I have replaced it with the drivetrain from a '69 camaro, and am looking for options on what to do with the original parts. If I cut the torque tube off, can I use the rear end to build a trailer? How are the axles held in, could I remove the 3rd member as well? From what I have seen, these things aren't worth much, and I would much rather put it to use than s**** it. Thanks, James C.
Why not put the tongue on the torque tube? I've seen trailers built similarly from regular axles in the past.
Thanks Rusty, That would tie my hitch directly to the axle with no benefit of a suspension. Also, the tube isn't long enough for what I have planned.
