Projects whats desireable on a 57 olds or interchangeable with a 56 chevy
Discussion in 'The Hokey Ass Message Board' started by dannyego, Feb 21, 2009.
  1. dannyego
    dannyego
    A friend of a friend is parting out a 57 olds 2 door. Im picking up the front seat for my 56 chevy because Im pretty sure it will work. Is anything else on that car useable for a 56 chevy, such as the new rockers he has in a box. Or are any of the parts desireable that I should pick up for a rainy day to help finance my project?
  2. Mule Farmer
    Mule Farmer
    from Holland MI
    I would grab the dash and steering column for sure and all the drive train. The 57 olds dashes are cool.
  3. dannyego
    dannyego
    If any of you guys need anything off it and I mean anything give me a holler. he has the whole thing diss***embled. His ba*****t and garage look like a swap meet.
  4. Almost nothing interchanges with a Chevy, the generator might work for you, and the rearend would bolt in but has the wrong lug pattern; that's about it.
    Who parts out a 2-door? That's what 4-doors are for.
  5. dannyego
    dannyego
    He gave up on the project and is moving. I wish I would have heard about it before he stripped it completely apart. I met him today and walked in on him cutting the frame in pieces to s**** it. It was a running 2 door super 88:mad:
  6. 56sedandelivery
    56sedandelivery
    The rear end will fit, but the spring hangers will need to be moved; they're not like a 57' Pont that will bolt right in. It'll be a 29 spline axle ***embly, but the housing is narrower than the 59-64 rears. The Hydramatic would be a slant pan; harder to find than the flat pans. Butch/56sedandelivery.
  7. MyEvilTwin
    MyEvilTwin
    Butch is right about the rear, but is still a decent item to have. If it were a few hours closer, I'd be interested in the rear.
    How about the engine? If the trans is decent/working. all the trim pieces etc... All of this stuff would bring in a few dollars to help finance your next project, or could be used for trading.
  8. bobwop
    bobwop
    from Arley, AL
    I would like the Black and Decker aquarium pump/J2
