Projects The Wade Model A Coupe: Build Thread & Photo Journal
Discussion in 'The Hokey Ass Message Board' started by Bass, Feb 20, 2009.
  1. kiwicowboy
    kiwicowboy
    from linwood nc
    I like the way you think,you work is grate and so clean,can't whate to see more.
  2. springer
    springer
    wow, i was drooling as i looked at the pics. that is some great work.
  3. krylon32
    krylon32
    from Nebraska
  4. LongnLow
    LongnLow
    i was lookin at your post for the 27th time today. i think you have a ghost in your garage! check out the shot of the ch***is on the ground, from the front.
  5. Awesome Brian!!
  6. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    Absolutely awesome! Best metal work I have ever seen, thanks for sharing!
  7. Gregg Pellicer
    Gregg Pellicer
    I dont know what to say except THANK YOU.Im just blown away. Im even more convinced that I dont make a pimple on a fabricator's *** GREGG
  8. Gasr57
    Gasr57
    from Ohio
    TRUE ARTIST! Those welds are unbelievable. That ch***is is a work of art. Glad you found someone willing to turn you loose to do it your way, and thanks for sharing. Keep us updated.
  9. AtomicDrew
    AtomicDrew
    from Zompton Il
    Look's like you are going to have to up the ante on your roadster build. I can see already you are going to be redoing some things. Incredible ch***is work Brian.
    -Drew
  10. rallisracing
    rallisracing
    Amazing work. I wish I had a talent....
  11. billylo
    billylo
    I fell like I just watched a mini series! Unbelievable again, Brian. I want one. I missed you at Decatur. Daryl said he saw you. I guess you found all the deals because I didn't find anything. Thanks for sharing. Billy
  12. Everything I can think of to say has been said at least once. You need a broom pusher? :) I need to leave corpus, there is plenty of inspiration in your shop, maybe some will just come to me through osmosis by being close by hahaha Great work. I am looking forward to most posts.
    Will
  13. psycho666
    psycho666
    from Wa
    that welding job made me wet...holy ****!
    i'm so jealous of your skills....
    lauren
  14. Bass
    Bass
    from Dallas, TX
    That's cool, Dave. Tell him I'd be glad to take a look at some his work at Boeing so that I can give him my thoughts on what he might be able to do better.
    Seriously though, I'm constantly learning and I'm definitley no engineer (although I did major in Mechanical Engineering at Texas A&M for as long as I could stand it)...so I do welcome constructive criticism. It would be nice if I had someone with a thorough engineering background that could come over and take a look while I'm figuring this stuff out to tell me if I'm doing things the best way....but then I'd probably never get anything done.
    I'm really more of an artist than an engineer...and this is really more of a hot rod than an aircraft. The lightening holes may or not be correct for the application, but that's not why they are there in the first place....they're there because I wanted them to be there.
    To be honest, I really don't think there's going to be any problems with structural integrity anywhere in this ch***is. Sure it could be stronger in some areas, but does it need to be? If anything I would say that it's 'overbuilt' (strength-wise) in almost every aspect.
    I'm not saying it couldn't be better...I always think I can do better the next time. That's one of the things that keeps me going. If my engineering is off, then it's most definitely a product of ignorance...but as I said, I do try to learn from each project and that's the best concession I have to offer.
    If the lightening holes were your friend's only real concern...and he's that far up the food chain in the mech. engineering world, well then I'm going to consider my experiment a success...at least visually. I understand where your friend is coming from (with his background) and I really do appreciate the input. I think that it's great that he has built a few hot rods...I would love to see them.
    -Brian
  15. ElBrujo
    ElBrujo
  16. BISHOP
    BISHOP
    B***.........You ****ing rule. You should be proud of yourself. To top it off, this is the pinnacle of great info and detail. The car and the thread!
  17. CoolHand
    CoolHand
    Alliance Vendor
    Strictly speaking, the guy is right (about the neutral axis).
    Putting a hole through any place else weakens the structure unnecessarily.
    That said, in automotive applications, this very rarely makes any practical difference at all (as evidenced by the literally millions of miles driven on axles and such with way too many holes drilled through them). Especially when you're talking about cars that weigh as little as these do.
    In a Formula One car where everything is on the razor's edge, I'd argue the point, cause the section then has to be made bigger to make up for the strength you've lost because of the holes you made (thereby negating the very reason you put them there to begin with).
    Here, it makes no practical difference. In this car, 40-50 pounds one way or another makes no difference, you're after the holes for aesthetic reasons, not weight savings, and the structure is plenty robust to make up for their presence.
    This is why people the world 'round hate engineers, 'cause too many of us can't hold their tongues on trivial matters.
    He's technically correct, but practically speaking, he's being a know-it-all jack***.
    You gotta know when to hold your tongue, and when to criticize. You gotta have some tact to know when is when. Engineers pretty much universally lack the region of the brain responsible for tactful interactions with normal people.
    It's a hurdle that some of us never get over.
    I'm just sorry that it landed in the middle of an epic thread such as this.
  18. I've just seen that rarest of things, a hot rod ch***is with a fully functioning X-member. So many guys go to great lengths to box the side rails and then blithely destroy most of the torsional strength of their frame by cutting away the stock X-member. Ford put that there for a reason and it wasn't to make the ch***is heavier. While some other design details of the Wade ch***is are questionable, you sure got that X-member right Brian and your workmanship is superb.
  19. DRD57
    DRD57
    Thank you very much for sharing in such clear and articulate detail. Your work is truly inspirational and impressive.
  20. crazed_lunatik
    crazed_lunatik
    from Arizona
    b***,
    as another mechanical engineer i would say they should be fine. the strength would be more in the flange than the web. to be sure, you would have to do a CAD model and proper FEA ****ysis, but those tools are expensive, and on complex geometries like yours, might not be as accurate as you would like if you are not highly practiced at it. that is an art in and of itself, really. or you could do a destructive test on a another piece, but dont post that. people would cry. i say again, your work is brilliant, and i have always lived by the adage that if you dont know if your build is enough, then overbuild it. i think you manage there and still make it pretty.
  21. Castr8r
    Castr8r
    I think that there are only a few individuals that can fabricate art that is functional. You are one of the best. The motor mount *** radiator support is outstanding! The curve of the metal, the placement of the "lightening" holes, just the simple elegance- WOW! I like the crossmember, too. The aesthetics of the "lightening" holes is really apparent in the ch***is shot from the rear; you should figure out a transparent body. It is a shame that this ch***is will be hidden beauty...
    I can't wait to see what you have in mind for the rest of the machine.
  22. MR. FORD
    MR. FORD
    from Austin, TX
    Top notch dude, as always. Always getting better too, RULER!:D The **** you think of..........!
  23. Jon Elley
    Jon Elley
    Brian ,your fabrication work on this frame is brilliant , you are a brilliant craftsman ,and I hope you dont mind, but you have given me alot of new ideas
  24. Beautiful work. I think i,ll copy you. Will have to be in another life when i hope to have real first cl*** welding skills and the patience you seem to have. I don,t see it happening in this life. Unless i go and retire real soon :D . Nope, not even then. I find woodworking easier.
  25. D Staig
    D Staig
    Brian, its great to see some new work from you as i too was wondering how your roadster project was coming along. To me that ch***is is pure art.
    I get a lot of inspiration from your finished cars down to your basic fabrication.
    Cheers!...and good luck.
  26. striper
    striper
    I'm embarr***ed :eek:
  27. KUZTOM
    KUZTOM
    Brian Hi, my son found this thread during the weeken,plus it was posted on the New Zealand Hot Rod mag forum.I just think your creative skill's are the best any one could wish for,you think out side of the square,Cant beleive any one can TIG that good,BEST work Ive ever seen !
    I find it strange that when we see A+ work like this, you get W%$#&^S bleating about this or that , from my experience, like the fella from Boeing their heads are stuck so far up there own ****,and to make them feel good they have to crtisize someone else's work.A lot of guys with all the fancy degrees are generally NOT very practicle..........
    You have given a lot of people around the world some of the best ideas to go think about for their own projects ,including me ;)
  28. kevron
    kevron
    brian i am a 59 year old my trade is a painter and decorater my hoby as allways been in building cool street cars and hot rods i have built lots and worked on a lot of factory cars ie ford gmh and crhysler and i have **** better engineers and ihave seen airoplanes fall out of the sky to you keep up the xellent work kev
  29. funnycar
    funnycar
    A real masterpiece: no other words!
  30. H eavenly
    A rtistic
    M etalwork =
    B ***!!!!!!
