Hot Rods Tire size fendered model A's
Discussion in 'The Hokey Ass Message Board' started by yngrodder, Feb 23, 2009.
  1. yngrodder
    yngrodder
    Show pics and your tire size please. I'm building a sedan and the tires I have on the rear are just to small.
  2. HotRodFreak
    HotRodFreak
    I bought 7.50 x 16 rears for my 29 roadster.
  3. Zookeeper
    Zookeeper
    235/75-15 on 15x8 wheels on the rear, 145 SR-15 on 15x6 front
  4. BBobb
    BBobb
    7.50 x 16 x 4.5 here
  5. dans30
    dans30
    Although not a sedan, I'm thinking about gong up a size on my model a rear tires also.
  6. Dean Lowe
    Dean Lowe
    145 X 15 front 275-65 X 16 rear.
    You're right about the small tire on the rear. You gotta' fill up a Model A rear fender.
  7. Chris
    Chris
    5.50x16 up front, 7.50x16 rear.
  8. abomber30
    abomber30
    from syc, ILL
    your a would look cooler with fish headlights
  9. yngrodder
    yngrodder
    Perfect, that is what I was looking for. I already have those for the front so I will order new rears.
  10. moon man
    moon man
    5.50, frount 750. Rears, look soo good....
  11. propwash
    propwash
    from Las Vegas
    These are 255/75R BFGs - I know some of you 'purists' eschew radials, but I've been building hot rods since 58, so I can do what I like.
    In my mind - this is how tires should sit inside A and 32 Fenders - whether they're bias-ply or radials
  12. propwash
    propwash
    from Las Vegas
    Just went and checked - those are 285s - not 255s
    dj
  13. Corn coupe
    Corn coupe
    from CZ
    Same size as Chris, but blackwalls and the rears are Michelin they are about an inch and a bit bigger in the overall cir***ference
  14. sawbuck
    sawbuck
    from 06492 ct
    how tall are the 750s?
  15. yankbuilt
    yankbuilt
    195/75/14 up front, 235/75/15 in rear.
  16. 29pu
    29pu
    o/t alittle but chris`s coupe is totally cool.
  17. 5window
    5window
    185/75R14 up front under cycle fenders,225/70R15 rear under full fenders. I would've gone bigger in the rear on the coupe, but at the time I bought the tires, PA required the entire tread width to be under the fender and this was the biggest size that would fit.
  18. HUGHES AUTOMOTIVE
    HUGHES AUTOMOTIVE
    Fronts 6.00-16 rears 750.16 car has not been lowered.
  19. Chris
    Chris
    Your car was a huge insperation when I did mine.
  20. model.A.keith
    model.A.keith
    235 X 75 X 15 Rears
    195 X 55 X 14 Fronts
  21. Obersten
    Obersten
    from Norway
    Rear 750X16 Front 550X16.
  22. Front:
    165R/80-15
    4 ½" tread width
    25" tall
    5" x 15" wheel
    Rear:
    P235/75R-15
    6" tread width
    28" tall
    6" x 15" wheel
    Interesting how the 235 is the tire size for many.
    Gears the car up about right and fills out the fender well nicely.
    Cycle fenders go up front later on.
  23. -impalamike-
    -impalamike-
    Is like to see some more of these. There were hardly any fendered A's on the mother of all tire thread
