what is a good carb
Discussion in 'The Hokey Ass Message Board' started by kustumizer, Feb 28, 2009.
  1. kustumizer
    kustumizer
    from Alton,NH
    I dont really know what to look for in a carberator, but I will describe my engine and see what you guys think.
    302 ford, bored .30 over, pretty large cam, lots of work done the heads, roller rockers, and a couple of other little things done to it.
    Im not going to be drag racing or anything, just looking for a good responding carb.
    Thanks nate
  2. fab32
    fab32
    Something in the 500-600 cfm range should do just fine if all around performance is your goal.. An Edelbrock or vacuum secondary Holley will do right out of the box.
    Frank
  3. hotrod30a
    hotrod30a
    edelbrock 1406 its a 600cfm with electric choke. very reliable and bomb proof
  4. I have an Edelbrock on the 350 Chev in my Merc and it works great.
  5. 40Standard
    40Standard
    from Indy
    stay away from barry grant's ****
  6. hotrod-Linkin
    hotrod-Linkin
    holley 570 street avenger...sweet
  7. chevyshack
    chevyshack
    Ive always used Edelbrock 600 cfm electric chock and vacuum secondaries. Ive got a Carter on my 383. Its exactly the same as the edelbrock except manual chock. Carter makes Edelbrock. Ive heard that the new Holly street advendure carbs are great. What ever you go with stick with nothing bigger than a 600cfm unless its gonna be a 600 hp monster or something.
  8. Retro Jim
    Retro Jim
    A Edelbrock 600 cfm ! That's what is going on mine with a big cam and 10-1 compression .
  9. hotroddon
    hotroddon
    Actually Carter doesn't make the Edelbrocks. Weber USA does. But they are based on the Carter design
    Agree - you can't go wrong with this!
    WoW, don't know anyone who would agree with that. Great carbs, especialy for racing.
  10. One that doesn't ooze,drip,belch and or catch fire >>>>.
  11. Defisch
    Defisch
    from Hudson FL.
    Had a 600cfm Edelbrock on the wifes camaro, ran great once i put a regulator set at 4psi. never any problems.
  12. scottybaccus
    scottybaccus
    Yup!
  13. MainProp
    MainProp
    I ran one on my old SBC 283, and it was flawless. Looked nice, ran nice, and I never had to touch it- EVER.
  14. shoveled71
    shoveled71
    Run an Edelbrock 600 on my 302 with mild cam and Edelbrock manifold, great carb right out of the box. Spike
