GM alternator one wire conversion?
Discussion in 'The Hokey Ass Message Board' started by deluxester, Feb 28, 2009.
  1. deluxester
    deluxester
    I remember years ago I had run a conventional gm alternator as a one wire type by connecting a jumper between the batt terminal and one of the two tabs at the top of the alternator. Does anyone know which tab is the correct one to use?
  2. flip7262
    flip7262
    from Minnesota
    Should be the one on the left side when facing the front of the alt.
    Junkyard
  3. budd
    budd
    terminal #2, the red arrow.
      40.6 KB
  4. v8 Bake
    v8 Bake
    if you replace the internal regulator with a self exciting one all you need is the big power wire.
  5. Desert1957
    Desert1957
    from Pa/Md
  6. R. Seghi
    R. Seghi
    why not just use a one wire alt. and convert your cars electrical system? Wouldn't that be easier then trying to jerry-rig a one wire system? can you say "HACK"?
  7. FalconMan
    FalconMan
    from Minnesota
    I have done it both ways. The 3 wire is much better if you ever need to replace it on the road. They are available cheap everywhere. A one wire..... you are screwed into buying a 3 wire and then jerry-rigging in the parts store parking lot.
  8. R. Seghi
    R. Seghi
    Not if you just break down and spend the money for the right parts. How much more does a one wire alt. cost? You can't carry a spare? This is why I carry Auto Club. To get me home safely or to a repair shop. **** just happens. It all depends on how you deal with it. What's the potentail of making things worse by hacking it? Or burning it to the ground? Bring Marshmallows, we'll have a bonfire.
  9. deluxester
    deluxester
  10. d2_willys
    d2_willys
    from Kansas
    One wire units are ok if 1) you like revving your engine up when it starts just get the alternator excited, 2) if you like having the voltage regulator monitor the voltage right at the alternator and not at the battery. You could have a not so good wire from the battery to the main alternator terminal and when you have big loads on the battery it will undercharge, because the sensing is done at the alternator. I prefer the 3 wire units.
  11. chickenridgerods
    chickenridgerods
    from DSM, IA
    How hard is it to do it the right way and route a sensing wire to your positive junction block? Certainly cheaper than lugging around a spare one-wire alternator and cleaner than jerry-rigging a three-wire in the parking lot.
    All you need to do is run one extra little wire. A monkey could friggin' do it.
  12. flynbrian48
    flynbrian48
    What? I just went to a NAPA store here and bought a one wire, 55 amp off the shelf, it's a stock item for conversions, even listed as "conversion alternator", in EVERY NAPA store. And what's with a spare? I've NEVER had an alternator fail on the road in 40 years driving.
  13. 49 lincoln
    49 lincoln
    from reno
    I had a one wire, but it didn't give me enough juice when I had lots of things going, so I converted it with a 3 wire internal voltage regulator and wired it ala Mad Electrical. Now it senses from a distribution block and keeps me supplied with plenty!
  14. farleydog
    farleydog
    used to build the one wire, all it is is a mid 70s and up se 10 or se 12 delco unit (se) standing for self energizing. it has a feild terminal which can be connected straight to batt term basically all your doing is byp***ing the ignition switch. down side is if you dont start car for weeks at a time it can drain battery. but works great for a daily driver. to be sure you have an (se) unit make sure it takes the flat 2 wire plug not the square type like used in the 60s.
  15. R. Seghi
    R. Seghi
    True, if your just keep your **** in good working order you won't need a spare, or a hack-conversion. I too have never had an alt. go out on me at any time. Or a starter, or a carb. Water Pump? Yes. But like I said before, this is why I carry AAA. Just in case.
  16. adc
    adc
    Any chance you could tell me what the part number(s) were...?
    The counter persons (high school help) at my local NAPA are often "challenged" when it comes to finding parts that everyone else easily locates.
  17. 53sled
    53sled
    from KCMO
    3 wires are superior to 1. Learn to read a diagram.
  18. yellow wagon
    yellow wagon
    from WI
  19. Bob Dobolina
    Bob Dobolina
    13-4011sw.
  20. Deyomatic
    Deyomatic
    from CT
    The alternator that Budd pictured above is the three wire type, right?
  21. wildearp
    wildearp
    from tucson, az
    I have wired several cars and have tried two different one-wire style alternators. IN both cases they would shut off at idle and produce low voltage at low rpm. It really doesn't take much more work to just hook up the other two wires as intended. People obsess about the 1 wire because their car is "so much cleaner", yet have so many other things wrong with it that the one wire offers no aesthetic improvement.
    A couple friends insisted their 1 wire alternators were the best thing since sliced bread, yet their batteries would keep going dead. ONe complained their stereo was full of static and cutting out. Stereos don't like to run on 8 volts...............
    Go with your one wire and defy the experts!!!!!!!!!!!
